Question about Keurig K45 Elite Brewer
Used My K-Cup reusable coffee filter for the first time today. was extremely disappointed. coffee too weak!
Tried a second cup adding more coffee, but it didn't fit, and made a mess
  • 3600 Answers
SOURCE: keurig B70, the my k cup , weak weak coffee !!!!!
It is best to take it to the store you bought it from and have them fix it and watch or replace at no cost to you. Tell the store what they said to you and have them show you how to do it. If you work on it and break it you own a broken machine. Hope this helps.
Posted on Aug 26, 2009
NiftyInsight
  • 15 Answers
SOURCE: unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
Posted on Feb 21, 2010
SOURCE: Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Posted on Mar 23, 2010
SOURCE: K-Cups disappointing
I had same problem and called Keurig. They advised me that the gasket in the upper portion, where the top needle is needs to be brought down about half way, almost even with the bottom of the top needle. Be careful not to poke yourself. I brewed a cup with the resuable filter assembly and it worked great. It should stay in that position until you use an actual k-cup. When using it will push the gasket back up, as it needs pressure to puncture the hole. To go back to the resuable filter, you will need to lower the gasket again. She advised me that they are working on a fix for this issue and will notify you of any replacement parts, as long as they have your current contact info.
Posted on Oct 04, 2010
  • 3 Answers
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Posted on Dec 31, 2010
LIKE DRINKING WATER WITH A HINT OF COFFEE
You have 3 selections, thus use #1 or #2 for a stronger brew. Naturally the water levels will differ. Get a Reusable Kcup device and pack your own coffee for better results. Get fine ground coffee or grind your own, and then pack the Kcup reusable with your grinds. A fast hot water flow is excellent.
Feb 11, 2014 | Keurig K75 Platinum Coffee Maker w/78...
I have a K10 mini cup keurig brewer. It worked fine until this morning. When I try to brew a cup, it comes out the top. It does with this with or without a k-cup in. I tried to clean out the needles...
First: You need to check a Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
Second: Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 27, 2013 | Keurig Coffee Makers & Espresso Machines
We want to try the reusable keurig filter but we cannot close the lid in order to use the machine what are we doing wrong
You need to remove the K-cup holder first...
Pull straight up on it and then place the reusable in there..
heatman101
Sep 19, 2011 | Keurig Platinum B70 Coffee Maker
When I use the K-cup to make my own coffee, water leaks all around the k-cup. What am I doing wrong?
Sorry to read about your problem, I hope this helps you out.
i hope you are saying you are using the metal reusable k-cup... and you have removed the regular k cup holder.. if so make sure you have the brown cap secure....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Keurig Elite B40 Coffee Maker
How do I make my own coffee in the Keurig? I have the reusable filter, but I don't know how to use it.
No problem, you will goto the maker, and open the latch, as if you are going to put in a k-cup..
Well that little brown holder, comes out..use 2 fingers and try to snap it out...when you get it out. put in the reusable filter..and you are done
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
I broke the peice that puts water through the coffee basket on a Keurig Elite B40 Coffee Maker where can I buy parts for this?
If you are talking about the K-cup holder that punches the bottom of the k-cups, they usually are not for sale, and you can only find them on ersale sites like Ebay.etc...
you could also go buy a "Keurig My K-Cup Reusable Coffee Filter"
and just use the main grey plastic filter holder... but you will have to puncture the bottom of the k-cups yourself before dropping them into the holder...
You wont need the filter basket or the lid if your using k-cups... just the filter holder...
dont forget to punch a hole in the k-cup first...
May 14, 2010 | Keurig Elite B40 Coffee Maker
Aug 01, 2009 | Keurig B50 Coffee Maker
Unit will not brew when pod is inserted; works w/o pod however.
May 29, 2009 | Keurig Ultra In Home Single Cup Brewer...
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Keurig K45 Elite Brewer Logo
97 people viewed this question
Top Keurig Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Keurig Kitchen Appliances - Other Expert? Answer questions, earn points and help others
