Question about Sony VAIO VGN-CR115E/P Laptop
Drivers for ACPI\SNYA008\4&276552de&0
Not getting the drivers
Code-28 driver acpi compliant system
right click on the driver with error and uninstall it. Restart your computer to install the generic drivers. Usually, computers generate their own generic drivers for the hardware parts in your computer. After doing that, update all drivers. You can find the updates in the website of the manufacturer. However, if you would like to get the correct drivers in no time then you can use RadarSync.
David
Mar 02, 2013 | Microsoft Windows 7 Ultimate 32 bit Full...
ACPI\HPQ0007\2&DABA3FF&0
Please mention the nature of the fault that is seen on the PC, for support log on to :
http://www8.hp.com/uk/en/support-drivers.html
Nov 30, 2011 | HP Pavilion dv9720us Notebook
I have a windows media center edition 2005 edition pc that had a new hdd installed and OS, programs, drivers, etc loaded up. Its an HP m7674n desk top. The issue is that I'm still missing one driver -...
I have the same issue but with 7250n, I have not found a solution yet. ASUS P5LP-LE , p4 2.8, 1g RAM, ASUS video card. palazzo.mark@yahoo.com
do you think it is worth $ to get recovery disk from HP?
Dec 15, 2010 | Computers & Internet
SCSI/RAID Host Controller/Driver cannot be found
Windows cannot find the correct drivers for this device. So, let's research a little bit.
Are you using SATA or RAID on the computer? If not, there is nothing that needs fixing.
If you are, then reinstall the RAID software from your motherboard installation disk, which should repair this issue.
If you do not have the driver installation disk from your motherboard, for whatever reason, go to their website. Almost every motherboard manufacturer provides easy access to drivers.
good luck
tony
May 22, 2009 | Computers & Internet
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Apr 10, 2009 | IBM ThinkPad T60 Notebook
Microsoft ACPI-Compliant Embedded Controller driver
Microsoft downloads and type in Microsoft ACPI-Compliant Embedded Controller driver or IBM Lenuvo site for this driver.
Mar 21, 2009 | IBM ThinkPad R32 2658 Notebook
Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: IntelĀ® Chipset Software Installation Utility for IntelĀ® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
Jun 18, 2008 | Intel D845GVSR Motherboard
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Feb 26, 2008 | Compaq Presario 700 470024-192 Notebook
Sony VAIO VGN-CR115E/P Laptop Logo
1,332 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
