Question about Pioneer AVH-X8500BHS
I have avh-x8500bhs. The face won't come down or open.Please help.
The face won't come down or open when i press the disc icon or the angle screen iocn.
How do I eject the Dvd
Press the eject button on the top right-hand of the keyboard. Be patient if the disc does not pop out immediately. Try pressing the button a few times or waiting a few seconds and then press the button again. If it doesn't eject, tilt the computer with the disc drive facing down and shake it gently as you press eject.[1]
Drag the disc icon into the trash. If the eject button isn't working, locate the disc icon on your computer's Desktop and drag it to the trash can. The trash can is located on the far right end of the Application Dock on the bottom of the computer screen.
Press and hold "Command" while simultaneously pressing "E."
Find the disc in the Finder. Open the Finder, located on the bottom left of the applications dock. Look on the left-hand side of the pop-up window under "Devices" for the name of the disc in your drive. Locate the eject button directly to the right of the disc name and click on it.
5
Eject the disc through an application if it is not in the Finder. In iTunes or DVD Player, click on the "Controls" drop-down menu located on the top toolbar and click "Eject Disc." You can also open iTunes and click on "Playlists" so that the left side bar pops up. Look for the CD icon with the appropriate name. Click the eject button directly to the left of the CD name.
Jul 11, 2015 | Televison & Video
Sideway screen INSPIRON mini how do I fix it
Changing the screen orientation of your Windows display can make your screen rotate at a 90-degree, 180-degree and 270-degree angle. By default, Windows operating systems do not come with a built-in mechanism to change the screen's orientation. Certain graphics boards, such as Intel, utilize hot keys to change the screen orientation. If the hot keys do not work on your computer, a program can be installed to create shortcuts that change the screen's orientation. One such program that is Windows compatible is called "iRotate," which is available to download for free.
Turn your computer on and wait for it to load. Once your computer finishes loading, make sure any open programs are minimized or closed. Press and hold the "Ctrl" and "Alt" keys on your keyboard. Press the corresponding arrow key on your keyboard for the direction to which you want to orient your screen. Press and hold the "Ctrl," "Alt" and up directional arrow key to return the screen to its regular orientation. iRotate Application Open the iRotate download site (see Bottom of page.) in your web browser. Click on the blue download link on the left-hand side of the page. The download link contains the text "iRotate" and has an icon of a floppy disc. Save the file to your computer. Open the iRotate file and follow the on-screen prompts to install the program to your computer. You can choose whether or not to put a shortcut on your desktop, place a folder for the program in your "Start" menu or automatically run the program after it finishes installing itself. Right-click on the iRotate icon in your taskbar. The iRotate icon is a blue rectangle that will display information about your graphic properties when you hover your mouse over the icon. Select a screen orientation from the drop-down menu. You can choose a 90-degree, 180-degree or 270-degree rotation. The "Normal Landscape" option returns your screen to its default orientation. iRotate
http://www.entechtaiwan.com/util/irotate.shtm
Mar 01, 2013 | Dell Inspiron Mini 10 Notebook
Activating the grad function?
Turn calculator ON.
If you see no icons, press MENU then 1: to enter the RUN screen. Press the SHIFT MODE key combination to enter (SetUp). Use down arrow to highlight the line Angle. Press the F3: key to activate the GRAD angle unit. Press EXIt to return to the RUN screen.
Sep 19, 2011 | Casio FX-9750GPlus Calculator
How do you find sine cosine and tangent on a fx-9750g2 calculator?
First you must setup the correct angle unit (as required by the problem you are solving).
  1. Open the [Run] application screen.
  2. Press [SHIFT][MODE] to enter (SetUp)
  3. Use down arrow key repeatedly until you see the line Angle:
  4. Press the F1 key to select Degree as angle unit. or F2 for Radian.
  5. Quit the setup configuration screen to return to the main Calculator screen (RUN/MAT).
Once the angle unit is correctly set,
  1. Press the function keys [SIN], [COS], [TAN]
  2. Depending on what function you pressed, the command sin( or cos( or tan( is displayed.
  3. Type in the angle value,
  4. close the right parenthesis and
  5. press [EXE]
A result should be displayed.
Feb 13, 2011 | Casio FX9750GII Graphic Calculator
The phone rings, however I cannot hear the caller
A sound settings have been reduced on the phone or possibly disabled from producing any at all. The sound could be re-enabled by locating on the phone the settings icon and navigating with the arrow keys until the sould iocns could be re-adjsuted. Once at the ssound icon on the phone, useing the option buttons to select sound instead could be customised by increasing volume scroll bar up and down to until found suitable ring tone.
Dec 05, 2010 | LG Cell Phones
I get the wrong answers when i'm trying to calculate sinus tasks. ex: sin 41 = -.9165215479 and the right answer is: 0.66 why?
I have no idea where you got that particular value of a sin (41).
At first I thought you might have been using the radian as angle unit, but that is not the right answer. I tried cos (41 radian) and I got -0.9877392775.
Any way, when you are using angles you must select that appropriate angle unit ( appropriate to your problem, that is).
I suspect you need the angle unit to be set to degrees. If you do you will find that sin (41 degrees)=0.656059029 which is close to the rounded up value you call the "right answer".
To set the angle unit to degrees
  1. Turn calculator ON
  2. If you see no icones, press the [MENU] key.
  3. Use arrows to highlight the RUN icon or press 1.
  4. In RUN screen, press [SHIFT][MODE] to enter the (SetUp)
  5. Press the down arrow 4 times to move highlight to the line Angle.
  6. From the three tabs that appear at the bottom of the screen, select the one labeled Deg ( by pressing the F1 key) and press [ENTER.]
  7. Calculate the sine with the angle unit set to degree and you will get the value you are expecting.
Nov 23, 2010 | Casio FX-9750GPlus Calculator
Why do i get incorrect answers with problems involving the tangent, sin and cosin functions on the casio CFX-9850G color power graphic calculator?
The only reason you get unexpected results is that the angle unit your calculator is configured for is not the one you think (degree, radian,grade).
To set angle unit to the one required by the problems you are solving,
  1. turn calculator on
  2. If you see no icons, press the MENU key
  3. Use Arrows to focus on RUN and press ENTER.
  4. In RUN screen press [SHIFT][MENU] to open the (SETUP) screen
  5. Scroll Down to highlight the [ANGLE] option
  6. Three Tabs appear at the bottom of the screen
  7. Press the Function key that is under the angle unit you require.
  8. Compute your trigonometric functions.
Here is a screen capture to illustrate what you have to do
Jun 16, 2010 | Casio Office Equipment & Supplies
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
JBL CS5 DVD Receiver - need region unlock code pls
  1. Open the disc tray
  2. Press and hold 6 on your remote
  3. Press MENU/PBC - The RC shows up on the screen
  4. By pressing MENU/PBC several times you can select the options: 0>2>3>4>5>6>0 (0 = codefree)
  5. When you've selected the desired RC, press "Angle"
    "Writing Region ID" appears on screen
  6. Hold down "Angle" until "Writing Region ID" vanishes. This can be up to 5 secs.
Apr 21, 2009 | JBL COMPLETE 6.1-CHANNEL HOME CINEMA SPE...
Onscreen angle icon cannot be disabled during layback of disc
After many long minutes of searching, I found the solution:
Depending upon your model of Pioneer player, you can switch this off in the Setup menus. Look for an entry about "Angle Indicator".
This worked for me. I had to stop the movie, go into the 'home menu' on my remote. Now I'm back to enoying Spirited Away without the annoying camera angle and blue line.
Feb 13, 2008 | Televison & Video
Pioneer AVH-X8500BHS Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
