Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubish WS-55807 HDTV 55" 1080
I have the 55" HDTV 55" 1080 Model WS-55807. I noticed about 2 weeks ago the picture when I first turn on the tv the picture would be warped momentarily, then normal. Now the picture is semi-permanently warped. (the colors are separated and the picture in the shape of an arc towards the middle.) I can turn off the TV for a short time and it returns to normal. How long until I totally lose the picture? What is the problem? Is one of the 3 (I think) picture guns going bad? Any suggestions would be great.
  • 1,694 Answers
Re: Mitsubish WS-55807 HDTV 55" 1080
RGB picture guns ( CRT's ) are ok. Your set needs a common
convergence circuit overhaul requiring replacement of two IC's,
part # STK392-570. Usual cost about 400.00.........T.
Posted on Nov 05, 2007
0 characters
3 Points
Noticed 2 white spots about a week ago.
It seems you have an issue with your DMD board, so pretty much you will need to replace it, those boards are running around 180 dlls, it's worth to try, but eventually you will need to give maintenance to the Tv
Jul 24, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Mitsubishi TV 2001 WS-55807/55" quick t power itse/ off ... $800?
The Code 1-2 actually tells you that there has been no error detected according to the service manual. What are the exact symptoms?
Jul 17, 2009 | Mitsubishi WD-65833 65" HDTV
Mitsubish WS-819 Protective Shutdown. 2 blinks, pause, 2 blinks
Over 95% of the time a 2 - 2 blink code on that model is a convergence output problem. You need to replace both of the convergence output IC's and perhaps the pico fuses feeding them voltage. The pico fuses are F9A04 and F9A05. They are on the same board with the convergence outputs.
May 29, 2009 | Mitsubishi WS-55819 55" Rear Projection...
No Picture after Wii Play: 65'' Mitsubishi HDTV 1080 (WS-65511)
mmm try this.... do u guys have the yellow white red cables hooked up to the front of the tv from the wii console? try loosening them up. worked for me. let's see how long it lasts .... !!!!
Dec 27, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
What happens
you have the V17+ chassis. The error code blinks a 2 digit code. So yours is either blinking a 12 for no error or a 21 for xray protect shutdown. Count the blinks carefull. it should blink a number pause then blink the second number. You will no doubt need the service manual. I have a good source for mitsubishi service manuals. Let me know if youd like more info and let me know what you discover with the blinking Led.
Mar 19, 2008 | Mitsubishi WS-48413 48" Rear Projection...
Trouble shooting 55" mitsubish hdtv 1080....
The clicking noise could be the lamp. It could be bad or just needs to be reseated to the ballast. Take the lamp out and look at the bulb. If it is not clear looking, it is bad and needs replaced. If it looks clear not smoking white, just make sure it is seated correctly to the ballast. After you have reseated the lamp (if it is good) and the ballast is still clicking when you turn on the TV, then your ballast is bad and needs replaced. You may also want to check the color wheel because it too will click if it is broken. Just take the top off the engine beside the lamp and look inside. The color wheel is made of glass and you can see if it is broken. If so it needs to be replaced.
Feb 28, 2008 | Mitsubishi WS-55805 55" Rear Projection...
WS-55807 doesn't power on
1) Check all fuse devices in power supply
2)Pc board with transformer possibly defective.............T.
Nov 07, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
177 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
