Rca led tv
Led 32b30rq not detecting basic cable channels during auto scan. will detect local digital channels if using digital anteana
  • 3,320 Answers
SOURCE: Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Posted on Mar 20, 2008
tonyw514
  • 66 Answers
SOURCE: Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
Posted on May 24, 2009
SOURCE: Unable to tune my LG Electronics Digital TV (Model 37LC2d-ec) to receive digital channels (have tried auto and manual program). TV will only receive basic standard channels. TV bought in Uk - now livi
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
Posted on Jul 22, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
  • 92 Answers
SOURCE: freezes during auto programming
The atsc or qam tuner in your Westinghouse LTV-32W3 HDTV is malfunctioning and needs to be replaced. Unfortunately you will need to purchase a new mainboard since it is integrated. Another option is to return to using an external tuner like your cable box.
Posted on Feb 07, 2010
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
Can I manually choose what Air channel I want to be using?
It doesn't matter what channel number it ends up on after a scan, as long as you do the scan with it fired up it should detect it. You should then be able to edit but why bother?
I don't understand how a channel number can be described as dumber than dirt, if it does not detect it on an autoscan through ALL channels it won't work manually.
All that said you will get much better results using the video and audio outputs rather than the modulated rf feed. Look here for how to get to those outputs, your TV will need a composite and audio input for that to work.
SEGA Mega Drive Genesis RCA Mod Tutorial Add Video And Audio Outputs To...
Jun 16, 2014 | Sceptre E465BV-FHDD 46" 3D LED TV...
My screen keeps telling me to auto scan channels?
This is for basic cable TV. If you have basic cable, go ahead and let it scan channels. If you have digital cable or anything else and use a INPUT or HDMI or RCA to watch TV then just ignore the scan channels prompt as you have a cable box that handles all that for you.
Apr 14, 2014 | Televison & Video
No Digital Channels Detected
Jason, good you have narrowed down the problem. So tv 1 does not detect channels. Re-connet and try making sure all cables are properly connected.
Mar 03, 2014 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
I have a 19 inch lcd isymphony tv and it keeps saying run auto channel scan. But I have no channels to scan for I'm in a barracks in camp Lejeune and we don't have cable here. I just want to use...
Tries unplug replug the tv like an hour later see if the tv reset it self back to factory mode setting it should stop this.Make sure tv is not on Cable,try Antenna setup just don't push for the scan function or yes answer.Tries used it with a HDMI cable for setup for the PS3 and used input like 1,2,3 so on this dosen't link to any airing tv stations functions.
Aug 09, 2013 | Televison & Video
My digital tuner does not work
have you tried entering the "tuning mode" and scan for possible channels?
if not , check for screen "menu" go to "tuning mode" and select auto scan
Jan 13, 2009 | RCA TruFlat 27F520T 27" TV
How do I set my PT-44LCX65 up to receive broadcast HDTV signals.
You should use the auto-program function in the customer menu. It will prompt you to select which antenna input you wish to program and then ask if you are on cable or receiving signals via "air" or "broadcast" mode. Allow the TV to load all the channels. You may notice that the auto program mode may move along quickly during the addition of analog channels and that during the scanning of the digital channels that it may look like nothing is happening. Patience is a virtue here. Wait until it has completely scanned both analog and digital bands and you will recieve both versions of the station's signal. If, for example, you have a local channel 5, the digital version will be 5-1, and so on.
michtech
Dec 18, 2008 | Panasonic PT-44LCX65 Television
Kingscott,
Caseybee
Mar 13, 2008 | LG 42LC2D 42 in. LCD HDTV
LCD 32 inch Auto Scan issue
I have experienced exactly the same issue on two Westinghouse sets. Try turning the set off when it reaches 83%. When I turn mine off and back on, it has saved the channels -- at least the ones it had found before it got hung up.
Aug 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Not able to scan stations
I don't understand why you would bother to scan channel when you have directv or dishnetwork???
directv or Dishnetwork required their units in order to watch any channel,which means:
A. Depending on your TV setting,if you use RF connection from your basic directv to the tv,you would have to leave the TV on Ch.3 or Ch.4.to view the rest of the channels,you have to change it from the directv or dishnetwork box. You are NOT able to scan the rest of the channels from the TV,bottom line!!
If you have comcast or your local cable provider,once you have activated,you could use the RF signal coming out from the wall plate straight to the tv and go to TV auto programming,it will auto scan the available channels for you.
Don't waste your time on directv.
If you are thinking about recording from your BASIC directv or dishnetwork box, you would connect SAT. signal from the wall plate to the directv box,then use composite video/audio output and connect straight to your VCR/DVD player under composite video/audio input. Now you could record the viewing channel to the VHS.
Aug 19, 2007 | RCA DRC8335
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
