Question about Black & Decker Garden
Bypassing micro switch
Need mico switich for FT1000 type 2
How would I go about bypassing the brake safety switch on a 3 wheeler mobility scooter
The purpose of the brake micro switch is for the controller to detect the scooter is in freewheel or in drive. To bypass it all you need to do is connect the 2 wires of the micro switch together.
Nov 22, 2014 | Health & Beauty
Tip
How to get the burnt popcorn smell out of your micrwave!
Put a bowl of charcoal in the mico, not matchlite or any other kind that has lighter fluid in it, leave it in the micro for 2 days then change out the charcoal for freash charcoal, you might need to do this for a week or so but it works everytime!
on Jun 07, 2010 | Microwave Ovens
Kenmore elite microwave troubleshooting
My GE microwave buzzes at times but otherwise works just fine.
Jan 20, 2014 | Microwave Ovens
What size the carbon brush on Black&Decker Ft1000 Electric Flex Tube Blower 140mph
I used 12 x 8 x 5 mm (L x W x T), 33mm long brushes and is working like new. Bought them thru eBay; 10 ea. boxes of 2 for $7.26.
Dec 26, 2012 | Black & Decker Black&Decker Ft1000...
2000 chevy blazer stuck in 4 wheel low is it the motor on the transfer case (on side or is it in the transfer case)
The motor is on the transfer case on the drivers side..it looks like a sparkplug type of thing and has a 3-4 pin plug...they cost about 30 bucks and are very easy to change...there are some other posts in here that mention the actuator for this motor and it is under the battery...you may want to read up on this too, as this may be the problem also
Dec 25, 2010 | 2000 Chevrolet Blazer
How can i plug in my 2 gb adapters into my motherboard?
You will need a card reader. and an adaptor to fit the micro sd card into.
You usually get the sd adaptor when you buy a mini or mico sd card.
If you dont have a card reader built into your computer, you can buy one very cheap.
Micro sd adaptor here..( from $1 ) http://www.amazon.com/s/ref=nb_sb_ss_i_0_10?url=search-alias%3Daps&field-keywords=micro+sd+adapter&sprefix=micro+sd+a&ih=5_2_0_0_0_1_0_0_2_1.98_298&fsc=9
Card readers here (from $1 ) http://www.amazon.com/s/ref=nb_sb_ss_i_0_9?url=search-alias%3Daps&field-keywords=usb+card+reader&sprefix=usb+card+&ih=4_2_2_0_1_0_0_0_0_1.29_243&fsc=8
Aug 04, 2010 | PNY 2GB microSD Memory Card
I need know in/out de control board transformer of microwave oven model no.JVM1653SH01 , because it is bad
$175.00 at www.partselect.com Are you sure it's the transformer?
  • NOTE. Be sure to bleed the capasitor off in this micro wave. It is the type that holds voltage. Very high mico fare and will kick the _ _ i t out of you if you touch it without bleeding it off first. Take a screw driver and ground one side to bleed off.
Please rate solution
Sep 05, 2009 | GE JVM1653 Microwave Oven
How do I use the mico sd card on this player?
I would recommend here:
http://www.newegg.com/product/ProductList.aspx?N=2070070068+1053118914&Submit=ENE&SubCategory=68&Tpk=micro%20sd
It honestly doesn't matter what brand of micro SD you stick in your MP3 player, so I wouldn't worry too much. Micro SD's are much smaller, so no, you can't use a normal SD in a Micro slot. Most however do have an SD "shell" that you can stick your Micro into, and use just like a normal SD card. Also I know that MOST mp3 players allow you to add pictures, videos, etc, and having a Micro SD inside should allow you to add things directly onto it, so i dont see why you wouldnt be able to access the contents of the Micro from your MP3.
Hope this helps! :)
May 28, 2009 | Sylvania SMPK8854 Digital Media Player
I have a micro-wave who stop at 59 segondes each time.on convectio and mico-wave.the probleme is model:r 1870 serie:424939
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Dec 04, 2008 | Microwave Ovens
Garden Logo
35 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
