Question about Dell Inspiron Computers & Internet
How to switch on the light of screen
While working in night or no light i need to see the keys and amunable to swtich on th LED light of screen
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
How do I reset my Samsung account due to abnormal factory reset and processed failed
U have to connect ur phn to th wall charger let it charge for five mins thn let it be connected to th wall charger swtich it of completely thn hold power thn volume down key a new screen will come with Android logo navigation to tht screen is done through volume up/down key beadvised th data of th phn will lost completely secondly remove th memory card if u have any
Oct 12, 2016 | Samsung Cell Phones
No power to set no led lights blinking
Could be an open internal fuse or power supply failure
Sep 06, 2016 | Panasonic Viera TH-42PX80U Plasma TV
My galaxy 3 has swtiched itself off and will not switch on again
Your Galaxy 3 is running out of charge. Please connect charger and charge for atleast 30 mins. Then try to switch it on by pressing the power key. If problem still remains, contact me.
Feb 09, 2013 | Samsung Galaxy S GTI9000 Smartphone
My led indicators for caps lock num lock etc not workinh in my lenovo G570 laptop
Hi, If you are using a keyboard that is wireless im sure you just have to change the battery on the keyboard.
However if the keyboard is connected to your CPU, then depending on your keyboard model, you may have to turn F LOCK (F Lock Light on) to access system key commands if they are labeled on the front of the keys, such as num lock , scroll lock and print screen.When you click on the Flock, the lights are either supoosed to click on or off.
view the keyboard status lights by using the On Screen Display (OSD) option, Ensure you download the software ,
from your start menu do a search for your keyboard, on th key tabs setting,
its important to make sure that the correct model number is entered,
double click on the light you wish to change, in the Reassign a Key wizard,
clear the Displays (key name) status on the screen check box to disable the on-screen display, or select it so that a check mark is in the box to enable it, and then click Finish.
HOPE THIS HELPS.
Jan 26, 2013 | Computers & Internet
I have a th-42pd60u and the screen is off and wont turn on. the red led light flashes 6 times
The Sc board or the D board has blown which is indicated by the 6 flashes of the led. You need to replace one or both
Mar 03, 2011 | Panasonic TH-42PD60U Television
Hi, Approximately eighteen months ago, I purchased a 42 inch plasma Panasonic television model number: TH-42pz77u) but Saturday night, the television turn off and have five blinking red lights. Then we...
The 5 blinks on the LED means that the main logic D board is defective and will need to be replace to fix the TV.
Check this site to find replacement parts to fix your plasma if you intend to DIY.
Let me know if you need further assistance.
Jan 15, 2011 | Panasonic Viera TH-42PX80U Plasma TV
This morning, all the buttons on the phone have stopped working except for 7, 8, 9. It was fine last night, and only this morning, I couldn't turn off the alarm on it and none of the other buttons are...
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Apr 14, 2010 | Nokia 6234 Cellular Phone
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Computers & Internet Logo
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
