Question about Samsung WF431 Stainless Platinum Front Load Washer - WF431ABP
Power button does not work?
No power to the machine. Power button doesn't light. The plug works but not the machine
3 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: I have a Samsung LN40B550.
the problem of your tv is that your power supply is already damage, try to remove the back cover of your tv but be sure to unplug it then try to follow the ac cord that is connected on your tv there you will see the power supply, then observed if their is a swollen capacitors or leaky capacitors it is easy to distinguish you will see an oil mark or wet mark in the bottom of the capacitor try to replace it but be sure to remember the proper place of the capcitor because it has a polarity.
Posted on Jul 05, 2011
SD Tech
  • 14553 Answers
SOURCE: Samsung LN40C610N1F. When plugged in, the red standby light comes on, but when I hit the power button the unit will not power on. The light doesn't blink or anything.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_19_2012_3_53_26_pm.jpg
if set opened look for puffed up caps like these on the power board.
Posted on Apr 19, 2012
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Power does not turn on when i push the power button
first make sure there is power to the outlet if it is agfi outlet push the reset button if it clicks its working but inany case plug something in to the same prongs that you know works(eg; lamp,radio,etc to make sure it is working. If it doesn't work go to the circuit breaker and look for a breaker that is not in the on position and turn it off the turn it on to reset it. If the outlet works,check the power cord for cuts fraying or any signs of damage and replace it if it is damaged. if the cord looks fine, check tho door switch(usually a pressure switch that must be fully depressed for the machine to start working. also is ther a power light on the unit? is it a top load or front load? what brand and model # is it?
Jan 09, 2012 | GE WCVH6260FWW
My LG washing machine has power but no light display and doesn't work. I washed a bathrug and when I returned the machine had power (makes a tone when the on button is pushed), but none of the...
I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
Oct 11, 2011 | LG WM2016C
Computer will not turn on. when power button is pushed, battery and power cord lights flash on and off. Plugging in does not help. How can I make my computer work again?
Try doing this:
1. Remove the battery and unplug the computer.
2. While there is no power connected, press and hold the power button for 30 seconds
3. Plug the computer back in, but don't insert the battery yet
4. See if it will turn on now, and if it does, insert the battery again.
Sometimes this works to drain some residual power that is still inside the machine. I've done this on a couple of machines and it has resulted in them starting up fine. If this doesn't work, you may have a more serious problem and need to have it looked at by a technician.
Aug 25, 2011 | Lenovo ThinkPad T61 Notebook
My washer was on when the power went out. Now all the controll pannel lights are on and a buzzer is going off. I tried unplugging etc.
It would help to know your manufacturer and model, but most machines will react fairly well to one of the following to reset them.
Power the machine off at the mains, hold the power button in and power it back on with the power button pressed it. Depending on the machine you will get a beep or buss or light flash and then the machine will reset and all should be well.
Option 2 is a simple disconnection from the mains for 20 minutes and when you power back up, the machine may well have reset.
If this doesn't work, drop a comment back and include your make and model and I will see if I can come up with some more ideas for you
Jul 21, 2011 | Washing Machines
Toshiba Satellite laptop will not boot. Shows power from outlet and battery but no indicator light is present for the last two in the five light sequence.
Its an old trick that got my Dell laptop working
Unplug the laptop remove the battery press the power button,...nothing will happen, wait a few seconds put battery back in laptop plug it in hold upside down press power button until it boots
If that doesn't work it could be a bad/loose/dead bios battery What is the model of the laptop?
May 11, 2011 | Toshiba Computers & Internet
Delonghi Magnifica Rapid Capucinno Power button not working. Hi all, We have a delonghi coffee maker that stops working few weeks ago. The machine doesn't power up. When you plugin into the outlet...
It's quite likely your unit had a blown thermal fuse caused by a bad thermostat. Test them by disconnecting one end and a meter should show continuity if the part is good. The pro's test them in circuit while the unit is plugged in, power showing across the part means it is bad. REPLACE BOTH PARTS TOGETHER.
Jul 02, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
I lost power and now I get blinking lights on my le Cube 185
I had a similar problem where both Small and Large cup buttons on mine blinked intermittently. I did a reset of the large and small cup flow levels based on the following and it seems to work fine now:
1. Switch off power 2. Press and hold Large cup button 3. Switch on power while still holding down large cup button
See if that solves your problem.
Aug 24, 2009 | Nespresso Essenza C100 Espresso...
Samsung WF431 Stainless Platinum Front Load Washer - WF431ABP Logo
14 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
