Question about Foundry Networks FastIron Edge 2402 24-Port Ethernet Switch (FES2402-DC)
FES2402 FACTORY RESET
NEED TO RESET TO FACTORY
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
Feb 05, 2017 | Computers & Internet
Lost password Nobis 1022C what do I do.
I already answered you. You need to do a Factory Reset.
  • How to reset 9" nobis tablet to factory setting? - How do ... www.askmefast.com > Consumer Electronics > TVs > Reset Nobis internet table recovery mode. You can perform a factory restore on the phone to get back in. power off phone, then boot into recovery mode by holding volume up ...
  • Nobis 9" Tablet 8GB Memory Dual Core - Walmart.com www.walmart.com > ... > Nobis 9" Tablet 8GB Memory Dual Core Nobis 9" Tablet 8GB Memory Dual Core. ... I have called customer support twice and performed a simple reset and a factory ... I went on the Nobis site to look ...
  • How to I factory reset my nobis 7" tablet? - Ask Me Fast www.askmefast.com > ... > Reset Factory reset nobis pad. The volume keys wont navigate when trying to factory reset my tablet? ... How to i factory reset my nobis 7 tablet?
  • Apr 03, 2016 | Tablets & eReaders
    Factory reset
    Factory reset Proscan PLT 70330 use power and volume buttons to reset.
    Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Factory Reset on Proscan PLT7223G or Tablet
    How to reset proscan tablet model PLT7033D to factory setting its locked
    want to reset my PIN on my Proscan PLT7033D
    Mar 23, 2016 | Cell Phones
    How to do a reset for irulu 9 inch tablet?
    In order to factory reset your device you will simply need to perform the following steps directly in order to reset your device.
    1. Turn your device off
    2. Press and hold the volume up button
    3. Press and hold the power button
    4. Release these buttons
    5. Use the volume up and down keys to highlight the factory reset option
    6. Press the power button in order to select the option to factory reset your device
    Nov 12, 2014 | Tablets & eReaders
    Factory reset
    Bro You Don't Need To Restore Factory Your Computer Just Renew Your Windows
    It Will Automatically Reset The Factory Setting
    Nov 06, 2013 | HP Pavilion zd8000 Notebook
    How to factory reset d-link dir-825
    The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
    If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
    Feb 02, 2012 | D-Link DIR-825 Wireless QuadBand Router
    Router name was reset without my asking. i need to set it back.
    how was the name reset and by who??????
    if you mean you have to reset your router to the factory default settings
    (note all settings will be lost you will need to reconfigure the router)
    you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, depending on your router) to reconfigure your router settings or if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
    Jun 26, 2011 | Computers & Internet
    Hi i need to reset my rvx 1000 to factory
    Page 42 or 69:
    "To reset all of the parameters to the factory-set values
    Use "9 PARAM.INI" on the SET MENU to reset all of the parameter values of all DSP programs within the selected group to the factory-set values (see page 42)..."
    Feb 09, 2010 | Yamaha RX-V1000 Receiver
    Reset to factory specs for blackberry curve 8330
    how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
    To reset the phone back to factory state:
    Go to Options -> Security Options -> General Settings
    Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
    Thanks.
    Jun 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
    Foundry Networks FastIron Edge 2402 24-Port Ethernet Switch (FES2402-DC) Logo
    51 people viewed this question
    Top Foundry Networks Computers & Internet Experts
    David Payne
    David Payne
    Are you a Foundry Networks Computer and Internet Expert? Answer questions, earn points and help others
