Question about Nilfisk C120 6-6 Pcad X-Tra Big Accessory Pressure Washer
Nilfisk c 120 will not start
Motor does not work
Where can i purchase parts for nilfisk sm800 sweeper ?
Direct from Nilfisk
7 1463637000 2 CASTER WHEEL
[PDF]SM 800 - NILFISK my.nilfisk-alto.com/Parts/Data/pdf/Part%20List%20MASTER%2035271.pdf
  1. Cached
  2. Similar
Part List US-English. 26-02-2015. Model: SM 800. SM 800. Page 2. Table of Contents. SM 800. Chassis system. 3. RECOMMENDED SPARE PARTS. 5 ...
NILFISK SM 800 ' Nilfisk Official Website
https://www.nilfisk.com/en/products/Pages/product.aspx?pid=9084801010
  1. Cached
SM800 is a manually-operated sweeper ideal for limited space or congested areas. SM800 picks up paper, leaves - even small screws, nails, bolts, cans, crown ...
Global contacts
Nov 07, 2016 | Cars & Trucks
How to open a nilfisk multi 20/30 casing to access motor
these machines are made to give the average person problems in repairing them to many screws and lock points,spring etc.your best bet is to take it to a vac repair shop for servicing,and save yourself the headaches!
Nov 06, 2014 | Vacuums
How di i open a nilfisk multi 30 to access the motor ?
nilfisk --- very difficult its easier to contact the agent and just get a replacement ,sounds like the aluminium rotor vanes have broke up and if this is the case then a replacement motor is easier ,i have taken these motors apart and they are a nightmare in the end it was either a replacement motor for a terrific cost or another car vacumn cleaner ,the later was the cheaper option
Nov 06, 2014 | Cars & Trucks
Nilfisk hoover will not switch on
Start with the basics, check for a reset button on the motor housing, make sure the circuit that the appliance is plugged into not a gfi circuit
thats been tripped. Keep in mind that when working with any electrical
-know your kimits!
Aug 16, 2014 | Nilfisk Vacuums
My Nilfisk Xtreme X200 vacuum cleaner will not start. The lights are workng on top but when I push start, it won't work.
Hi There,
I work as the tecnician for VacuumSpot and have done many repairs on the X200 extreme from Nilfisk. There are 2 reasons for the fault you are describing. THe first is that the machine has overheated due to a lack of cool air and has tripped the thermal cut out. This is usually as a result of using generic bags (not originals), having an old blocked filter or having a blockage in the hose somewhere. If the machine starts okay after a couple of hours of rest replace the bag, check the filter and if its dirty change it and check for a blockage in teh hose.
If it does not start after time to cool off you may have a faulty motor which is not an easy one to repair so I would suggest you take it to a Nilfisk agent to be assessed.
Mar 29, 2013 | Washing Machines
Nilfisk vacume bearings
Hi There, If you could provide the model number of the machine that would help. However as a general rule if it is the motor bearings you are after then normally you replace the entire motor. If it is the roller brush you are needing bearings for you can get them from any bearing supplies store. If you are looking for any nilfisk parts in Australia then vacuumspot is the go.
May 27, 2012 | Vacuums
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
My Nilfisk King 505 vacuum has decided not to go all of a sudden, was working fine, and now wont, could it be the start button has worn out?
Just had the same problem with mine. I am thinking the on/off switch too, but it could be motor related.
Jan 03, 2011 | Vacuums
Nilfisk c120 vacuum - no power
The fuse is part of the motor so is not something that can be changed. Make sure that there isn't a break in your power lead at the plug.
Mar 15, 2009 | Vacuums
Nilfisk C120 6-6 Pcad X-Tra Big Accessory Pressure Washer Logo
35 people viewed this question
Top Nilfisk Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Nilfisk Garden Expert? Answer questions, earn points and help others
