Question about Sony ICFC218 Clock Radio
24 hour time
How do I get the time to regular time instead of 24 hour time?
Why does time keep switching to military?
you have it set on 24 hour time instead of 12 hour time
it will change over at midnight to military time as that is when the 24 hour period ( military time ) starts
May 01, 2015 | Elgin Travel Alarm Clock
What is the differencew between 12 and 24 hour?
12 hour is regular time and 24 hour is military time, example for military time would be 06:00P.M. regular time or 1800 for military time.
Oct 08, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
My timex indiglo Ironman triathlon watchhas twelve hours of military time and then twelve hours of regullar time. HOW CAN I GET RID OF THE MILITARY TIME AND GET ALL TWENTY FOUR HOURS OF REGULAR TIME???...
Actually all the hours are military time. They are the same for the first twelve hours of the day. If you go through the setting procedure it will ask you if you want "12" or "24" hour time. Select 12. "24" is military
May 23, 2011 | Timex 27191 Wristwatch
Time is in miltary time with a 24 hour clock. I want it regular
It's in the manual which is available at Bose.com
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
May 21, 2011 | Bose Wave Radio
Canon PowerShot SD4000 IS - How do I set the time for a 12-hour clock instead of a 24-hour clock?
I found that there is no specific way to switch it to 12 hour time vs. 24 hour military time.
Just found the instructions for setting the time from the menu.
Dec 26, 2010 | Canon SD4000 IS IXUS 300 HS Digital Camera
How to change from military time back to regular time on a digital indigo watch with 4 adjustment buttons?
Thank you for contacting FixYa.<br /> <ol id="ecxintelliTxt"> <li id="ecxjsArticleStep1"> Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.<br /></li> <li id="ecxjsArticleStep2"> Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.<br /></li> <li id="ecxjsArticleStep3"> Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.<br /></li> <li id="ecxjsArticleStep4"> Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.<br /></li> <li id="ecxjsArticleStep5"> Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.<br /></li></ol> Contact TIMEX for further assistance at:<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads
Aug 25, 2010 | Timex 1440 Nylon watch
I have a Nexxtech Watch that is both digital and hand driven. I have somehow switched the regular time to a 24 hour clock and don't know how to switch it back. The manual says nothing about it. Any help...
These basic instructions are for most digital watches (and these are for regular to military but you can just follow same instructions to get to oposite) Hope this helps!
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 21, 2010 | Watches
I have the 444100 model and for somw reason i see
to change the clock from 24 hour time to regular am, pm time, all you have to do is press and hold the "up" button. it should change back to regular 12 hour time.
Oct 29, 2009 | Equity Time USA Sky Scan 44100 Clock Radio
Reads 24 hr instead of am and pm
Push and hold alarm time button to bring up “SETUP MENU”. Push the right tune ">"button 3 times and that should bring up the 12/24 hour display. Push the time + button to set back to 12 hour time.
Mar 05, 2009 | Bose Wave Radio
24 hour time
Per the instruction booklet: hold down the clock set button and then press on/off to toggle between 12 and 24 hour clock settings.
Sep 21, 2006 | Jensen JCR-260 Clock Radio
Sony ICFC218 Clock Radio Logo
70 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
