Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
"error 302" printer reading error 302
How could I solve sc 302
sc 302 cause dirty copy, if u see the dram it is dotted, replace dram or charging roller..
Sep 25, 2014 | Ricoh Office Equipment & Supplies
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
  • Cycle power on the Printer.
    1. Turn the printer off.
    2. Wait 10 seconds.
    3. Turn the printer on.
    4. Determine if the issue still occurs.
  • Download the latest Firmware Update from www.support.dell.com for this Printer.
    Review the information on the page and take note of Installation Instructions.
  • If the latest Firmware did not solve the problem, Please contact Dell Technical Support for further advice.
  • Apr 26, 2014 | Dell Office Equipment & Supplies
    How to clear error code SC302, Dsm615 nashuatec
    Yes, mine were successfully RESET from the error code SC:552 and SC:302. Machines runs good, but i about to wander what could be faulty inside, it took one month after error code 302 exist. Mine was exactly DSM615 same model same error code 302 (this is really 302) which resolved by reset. Hopefully machine will run good for two months.
    To RESET it
    1. Press Yellow button
    2. Press 1, 0, 7
    3. Hold Orange button for 3 seconds
    4. Select MODE 5
    5. Select Clear Memory (or something like it) (801)
    6. Select 002-Engine
    7. Select EXECUTE
    8. Turn the switch off and leave it for a minute
    9. Turn back machine On.
    10. Done, or else there could possibly something else.
    Good Luck....
    Thanks for using Fixya.
    Mar 04, 2013 | Office Equipment & Supplies
    Error code sc 302
    Hi
    This error indicates problems with the laser motor on your printer.
    Have it replaced.
    Mar 01, 2012 | Office Equipment & Supplies
    My printer ricoh 2045 show an error sc 302,not print image correct
    i have an error on my printer sc 302 how i can clear it easily .printer is ricoh 3045
    Aug 11, 2011 | Ricoh Computers & Internet
    Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
    SC:302
    Charge roller current leak
    Symptom: A current leak signal for the charge roller is detected.
    Possible Cause:
    ?? Charge roller damaged
    ?? High voltage supply board defective
    ?? Poor connection of the PCU
    May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
    The machine is display error massage reads as follows error occured sc:302
    Can you please Indicate what is the BRAND and the MODEL of the machine? Thank you..
    Jan 13, 2011 | Office Equipment & Supplies
    Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
    sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
    Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
    Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
    18 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
