Question about Apple G3 Computers & Internet
Firmware upgrade firmware leads to problems, rectoren original firmware
  • 32 Answers
Do you use Time Machine?
If so you you can go into time machine to the time you had old firmware and reinstall from there. Or do you still have old firmware? if so delete new and reinstall old. If you have clean my mac it will find anything on your mac that is associated with new software when you delete that might cause you problems.
Posted on Nov 10, 2015
200E freezes up
A 200e that locks up usually need a memory and a firmware upgrade. The original 200's only have 32mb of internal memory. The upgraded mini print board that is used in the 730 has 64mb of memory. This 64mb board was used in the 200 as a upgrade and this stopped the lock up problem. Also over the years Bernina has improved the firmware and this also cures the lock up problem. The latest and probably last firmware version for the 200e is version 5, also called the cutwork version. The easiest thing for you to do would be to take your 200 to a dealer and have them install a 64mb mini print board and also upgrade your machines firmware to the latest version 5. Also if you have loaded embroidery designs in your machine, remove them as they use up the machines memory. When you get too many designs loaded even if you have a 64 MB board in your machine you can still have lockup problems.
May 28, 2014 | Bernina Artista 180
Tip
How To debrand, unlock, upgrade firm and fix dead and brick phones, sony...
******** ALL NOKIA PHONES *********
(Debranding, Unlock codes, Remove security codes, upgrade Firmwares)
Recommended
* Original cable that came with your phone
* Nemesis service suite (NSS)
* Phoenix Service Software
* Windows Xp sp2
* Original phone software & drivers
Software links
http://www.b-phreaks.co.uk/index.php?main_page=page_2
http://thepiratebay.org/torrent/4413095/Phoenix_Service_Software_Version_2008.4.7.32837_for_nokia
for support on firmwares bertus_kriel@yahoo.com
******Sony Ericsson********
Recommended
* Original cable of phone
* Sony Ericsson update
* X++ software
* Jdflasher
on May 03, 2010 | Cell Phones
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Apr 15, 2010 | Minolta magicolor 2300W Laser Printer
I have also the same problem and after firmware upgrade i found that my drive does not detected by my pc's bios setup. is there any solution for backup the process or repair the drive.I edited the...
did u upgrade ur BIOS firmware ?
if so it's gone corrupt...if u have the backup of the original firmware...then FLASH the BIOS with that...else u may have to change the BIOS chipset....but that may be a tricky issue as the chip is fixed in the motherboard....
Cardinal Rule 1
NEVER UPGRADE / NEVER MAKE ANY CHANGES TO UR FIRMWARE ON ANY HARDWARE.....THE HARDWARES ARE MFG TO AND FIRMWARES ARE INSTALLED TO WORK THE WAY THEY ARE MADE...99.99% of the people who made changes to the firmware on any of their hardwares....have always faced issues later with the hardware...
Rule 2,
Always take a backup of the original Firmware if u can else dont venture into this complicated issue...
Dec 20, 2009 | LG (gce-8525bb) CD-RW Burner
A really bizarre problem with WRT-160N. I have the Network Connection Status open and the connection speed cycles thru from 130 Mbps down to 1.0 Mbps within about a minute. It keeps doing it! I have never...
i had that happen with my wrt54g it would go from 54 to 1 and start over again well i learned my leason there i tryed reverting to the original firmware and ended up toasting my router so dont try that :) im not to sure what the cause of this is either i do think that it in the router and not the wifi card tho
Sep 30, 2009 | Linksys WRT160N Wireless Router
Won't boot up and not recognised when connected to PC
MANUAL FIRMWARE UPGRADE PROCEDURE:
During the upgrading of the firmware, if you turn off the power of M800, either by manually switching off the power or removal of the battery, the file system of M800 will be damaged, which will lead to booting failure problem. When this happens, you will not be able to turn on M800. Booting failure problem can be easily repaired by “manual firmware upgrade”. The procedures for manual firmware upgrade are as follows:
1. After firmware upgrade, only the blue LED under LCD is on, but LCD display is not turned on, please proceed manual firmware upgrade.
2. Remove the battery.
3. Put the battery back into the player again.
* Notice ! : Do not turn on the power.
4. Connect the player to your PC.
5. While pressing the volume down button, power on the player.
6. Now PC should recognize M800 as one of its hard disks.
7. Download the latest firmware file into the root folder of the player.
8. Disconnect the player from your PC.
9. The blue light LED under the LCD display will flicker.
10. Wait for about one minute, blue LED is off. Turn on the player.
The manual firmware upgrade is now completed.
Jan 04, 2009 | Audio Players & Recorders
Sound problem after upgrade 6270
well take the phone to a mobile service center and have the phone's firmware downgraded.
Jan 01, 2008 | Nokia 6270 Cellular Phone
Jukebox Zen Xtra 40 gig
You probably have Winders Media Player 11. If you can find another computer that has WMP 10, you can use that computer to do the firmware upgrade, then go back to the original computer. Thingsa should work fine. Otherwise, you need to unistall WMP 11 and WMP11 runtime. Another case of Billy messing us up. And don't even get me started about vista....
Aug 14, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Firmware Upgrade
Unfortunately, a failed firmware upgrade is the one thing you can't recover from. The only reset available on these devices is just going back to the original factory configuration. If the base software itself has been corrupted, then I'm afraid there is no way to recover. If the device is still under warranty, contact the vendor to arrange a replacement, or bring it back to the store from which you purchased it.
Sep 20, 2006 | Cnet CNIG914 Router (NWCNIG914)
Computers & Internet Logo
133 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
