Question about Refrigerators
What are the dementions of model 106.58902800
What is the height of refrigerator?
I need exact dementions for my kenmore bottom freezer refrigerator model 795.7130-looking for the exact height
what is wrong with you taking a tape measure and measuring it yourself, then you will know exactly what measurement you want
Jul 08, 2016 | Kenmore Refrigerators
What is the listed cubic feet and exact height on back without door hinge?
Make and model number may help with this query or you could just google
Make model specs
Or
Make model height
Nov 24, 2015 | Refrigerators
Interior cargo measrements 91 hondacivic
Mine is:
Width 48"
Depth 33"
Height 14"
Hope this helps.
Mar 27, 2015 | 1991 Honda Civic
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email INFO@MALBERAPPLIANCE.COM.
Oct 17, 2014 | Malber P21 Front Load Washer
The width of my refrigerator is 27. Inches. What is the cubic feet
That depends on how high and how deep the refrigerator is.
For example, if the height and depth are both 27 inches then the volume is about 11.39 cubic feet. If the height is 36 inches and the depth is 27 inches then the volume is about 15.19 cubic feet.
May 25, 2014 | Refrigerators
I need the dementions for a battery
measure the old battery or measure the place where the battery sits, be carefull of height so the top lockdown will fit
Apr 03, 2014 | 1993 Saturn SW1
How many cubit feet is my refrigerator is a 2000
Length times Width times Height
In your case a refrigerator, assuming you want to find how many cubic feet the inside (storage) has, inside depth times inside width times inside height. This in case you want to find the interior cubic feet. Hope this helps...........
Nov 23, 2010 | Refrigerators
Battery size for a 2003 chevy tracker
Here is the information on the battery size from NAPA. The CA(cranking amps) and CCA(cold cranking amps) can be changed within a certain amount but the dementions should stay the same as well as it being a top post battery.
Battery CA @ 32 Degrees F : 780
Battery CCA @ 0 Degrees F : 625
Battery Height : 8"
Battery Length : 9 1/16"
Battery Load Test Amps : 312.5
Battery Posts Type : Top Mount
Battery Reserve Capacity : 95
Battery Voltage : 12
Battery Weight : 32.5
Battery Width : 6 13/16"
Nov 16, 2010 | 2003 Chevrolet Tracker
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
