Question about Schumacher SCUSEM1562A 1.5 Amp Battery Companion, Maintenance Charger 6 and 12 Volt SEM1562A
Red trouble light stays on
The trouble light comes on after being connected for a short time
I am having problems with Lionel Fastrack layout. When I put electrics to the layout the green light comes on and I think all is ok. However as and when I start to increase the power the red light A.
remove all the cars and engine from tracks and try it, if green stays on add one car back to track at a time and try it , when light turns red , the last car added is the problem
Mar 20, 2016 | Crafts & Hobbies
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
I have a Fishman pre-amp mod MKAB Acoustic Base Optimized in a Michael Kelly Dragonfly 5FL TBK.. as soon as the plug is pushed in the jack, the battery lite on the amp flashes for an instant , then goes...
Most acoustic/electric pre-amp's red light comes on when the battery is low & ready to die. The red light flashes when you put the jack in because the battery light takes a fraction of a second to proccess. If the red light flashes off & on when you push on the pre-amp, it is probably because you are causing the battery connector to short or disconnect giving the pre-amp low voltage so the red light comnes on.
Nov 06, 2010 | Fishman Audio Players & Recorders
Red wireless light wont turn green, no wireless connection found, stays red all the time dv7-1020 pavillion notebook, no wireless switch that i can see just the light in upper right, stays red, all the...
I have a tx 1000 with pretty much the same problem. Short answer is : if you are still under warrenty demand that hp replace the entire unit (basically they put together a lousy design, it doesn't allow for adequate ventilation and consequently the motherboard cooks itself and other components attached to it. swapping out parts will only briefly "fix" the problem.
the simplest cheep fix is to get a usb wifi adapter and connect with that (untell eventually the machine will cease to boot, lights will come on fans will run but nothing else will happen)
and you like me will not only be the proud owner of a really cool looking paperweight but also will never consider buying anything from HP again.
Oct 10, 2010 | HP Pavilion dv7-1020us Notebook
I have a kdf-50e2000. when i turn on the power the green light comes on then goes off and red light comes on blinks 3 times on power and screen stays black. changed lamp and reinstalled(just bulb). picture...
Check the lamp door switch. This switch is really cheaply made. The switch is not available. short rhe wires to fix the problem. then never change the lamp witout unplugging the ac power in the future.
Oct 30, 2009 | Televison & Video
Hitachi 50UX53K Ultravision will not stay on
The set is going into shut down mode for avariety of reasons. Some of the more common problems are vertical o/p ic bad connection or failure, poor solder connection usually in the power or hv section or possibly comb filter circuit breakdown causing 12V line to short. This set incorporate 7 or more shut down circuits and any one of them could be triggering - more trouble shooting is required
Sep 18, 2009 | Hitachi 50UX52B/53K 50" Rear Projection...
Switched amp to anther car red protector light stays on i have a quantum audio 2400 amp
unplug input raca's one at a time. turn off, then on. repeat until all you have is the 12Volt wire, the remote wire and the ground wire connected. if you get it to work after you unplug one of the rca's then you have a short. if not then remove all speakers connected, again one at a time until you don't have anything connected. this way you can find out which component is shorted. if you unplugged all rca's and speaker out wires and unit still stays on protect mode, check fuses. if ok, then your amp may have shorted out.
Sep 15, 2009 | Quantum QA2260 Car Amp
Amp is going out.
Have you tried replacing all of your fuses? If that does'nt work check your ground........ I would check all your connections also could be a connection shorting out causing your red light to come on.
May 10, 2009 | Car Audio & Video
Schumacher SCUSEM1562A 1.5 Amp Battery Companion, Maintenance Charger 6 and 12 Volt SEM1562A Logo
47 people viewed this question
Top Schumacher Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Schumacher Measuring Tool and Sensor Expert? Answer questions, earn points and help others
