Question about RCA 244889 Remote Control
I have a trutech t.v. and i want to program it useing a rcu703sp
I'm trying to program a trutech t.v. using a rca universioal remote rcu703sp
I'm having the same problem with my Trutech tv and the RCA remote. My email is legolastt2002@hotmail.com If you have solved it, id appreciate any and all help. Thanks
Posted on Aug 29, 2009
RCA universal remote won't program to my TruTech T2000-FT
Hello
There is only one code for Trutech and it is [1208]
This code is with RCA RCR 311B remote control. OK.
Jun 30, 2011 | TruTech T2000D TV
I need the Magnavox TV codes for a RCA remote control model RCU703SP.
You can get the codes on the link below if the magnavox codes do not work try the philips codes Philips and magnavox are made by the same people.
http://remotefinder.rca.com/default.aspx?site=rca
Good Luck
Nov 28, 2010 | RCA Universal Remote Control
I have an rca rcu404n remote i need the code for trutech tv.
RCA does not list a code for the Trutech TV. Trutech says that their TV is not compatible with universal remotes.
Some people have said that they had luck with Daewoo codes. You could try 016, 190, 005, 171, 004, 006, 017, 127, 196, 202, 222.
If that does not work, you might also try the code search method.
  1. Turn on the device you wish to program.
  2. Press and hold CODE SEARCH until the indicator light lights, then release.
  3. Press and release the device you are programming (tv,vcr, or dbs). The indicator light will blink once then remain lit.
  4. Press and release off-on until your device turns off. You may have to press off-on up to 200 times.
  5. When your device turns off, press the ENTER button and the indicator light will go off.
Nov 11, 2010 | RCA RCU404 Remote Control
SORRY IM NOT SPEAK INGLESH..
Try this website for codes www.replacementremotes.com or www.tvcodes.com Let me know if this helps or you need more assistance.
hardrocko
Feb 03, 2010 | Televison & Video
How do i program my remote control rcu703sp and my
Programming a Device using Code Search:
1.
2.Manually turn ON your device (TV, VCR, Cable Box)
3.Press and "HOLD" CODE SEARCH
4.Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type
of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
5.Release CODE SEARCH.
6.Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
7.Once the device turns off, press and release ENTER.
8.With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
1.
2.Find codes for each device and brand below.
3.Press and "HOLD" CODE SEARCH.
4.Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable).
When the selected device button flashes proceed to the next step.
5.Enter the three digit code from the TV, VCR or Cable Box code lists.
6.Release CODE SEARCH.
7.With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using
another code number from the lists.
Mar 16, 2009 | RCA Universal Remote Control
RCA DIGITAL CONVERTOR BOX
The consensus seems to be that TruTech is made by Daewoo so you might try their codes and their website for a download of any instruction manuals.
Jan 01, 2009 | RCA 3-Device Universal Remote
Have a trutech flat screen.Need to use a universal remote w/large
Try calling these numbers for TruTech technical assistance for your problem. 1-888-252-6252 and 1-800-252-6123. I hope this helps you with your problem.
Nov 14, 2008 | TruTech PLV16320 Television
CODE FOR TRUETECH TV
There are two useful websites that give detailed instructions on how to program your RCA universal remote, even if you do not know the codes:
1) THOMPSONTV.COM/RCARC.HTML
(Use this website's instructions if your remote has a
CODE SEARCH button)
2) WIKIHOW.COM
(Use this website's instructions if your remote does not
have a CODE SEARCH button. Once you are on the
website, type HOW TO PROGRAM AN RCA
UNIVERSAL REMOTE WITHOUT A CODE SEARCH
BUTTON into the searchbox, and start the search. Then
click on the subtitle dealing with searching without
a code search button.
Hope this info helps you out. Please take a moment to rate this solution, by using the rating system below. Thanks.
Jul 28, 2008 | Televison & Video
RCA universal remote RCU703SP wont program Magnavox TV
cheap universals dont hold as many codes, the best universal remote is the all for one range with the best being the comeleon
Jul 23, 2008 | Philips Magnavox Learning Universal Remote
RCA 244889 Remote Control Logo
321 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
