Question about Tiny Love Symphony Motion Deluxe Baby Crib Mobile
It keeps rotating without turning it on
It starts rotating as soon as you put it in the holder even without turning it on
What could be causing the front axillary fuse to keep blowing? Even bigger fuses blow.
fuses blow from over current( dead short) they are rated at lower than what is required so that the wire doesn't burn
If you keep putting in bigger fuses without fixing the dead short, eventually the wire will melt the plastic insulation off and the vehicle will burn
Apr 29, 2016 | 2005 Buick Rendezvous
I have a Kitchenaid YKHMS147HW microwave that started turning on by itself, and will not shut off unless I unplug the unit. If I put food in to cook, the food starts cooking as soon as I plug the unit in,...
Sounds like stuck relay contacts. Magnetrons need a high voltage source which is controlled by a micro to relay and then from relay to voltage source. Even the turntable works via a relay.
Oct 14, 2013 | Microwave Ovens
Why does my turn signal fuse keeps blowing as soon as I put it in?
You have a point in your turn signal wiring that is shorted to earth, you may be able to determine what side it's on if it only blows when you turn them on one way, you should check each bulb holder by removing all the turn bulbs and turn the signal on, if it flashes on the instrument cluster (will be rapid flashing) then the issue will be with one of the bulb holders, try putting the bulbs in one at a time and if it stops working you have found the corner of the car where the issue is an should be able to find the fault from there
Mar 05, 2012 | 1997 Infiniti.5 Q45
2004 Ford F250,6.0 Deisel .When starting cold,won't turn above1500 RPM,without choking out black smoke,hacks and coughs till back to idle then idles fine ,not drivable till idles for half an hour,will not...
Ford 2004 6.0, Driving down road seams like when it starts warming up it starts Missing or accelerating,jerking,as long as you keep the acceleration it seems to work as soon as you level it out it starts missing,even dies at stoping sometimes...Changed fuel filter, put fuel additive in tank still missing,HELP
Jan 02, 2010 | 2004 Ford F250
Pfaff 2040 Tiptronics bobbin case rotating out of position
Sounds like you need to put a drop of clear sewing machine oil in the raceway of the hook. Then sew on some scrap material to soak up the excess oil.
Mar 10, 2009 | PfaFF Tiptronic 2040
Tail &.. indicator lights[L.E.D.] are constantly flickering dimly, even tho lights are turned off .Starts soon as ignition switch is turned on.
This sounds like a earth problem. Have your earth connections cleaned and checked. You may need to replace your rear light bulb holders.
Sep 29, 2008 | Volkswagen Touareg Cars & Trucks
MICROWAVE TURNTABLE
Does it turn for just a moment or does it keep turning?
If it's just for a moment, that's normal.
If it stays on, either your top or bottom door switch is sticking or it's door switch mount is loose or broken.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
What is your brand & model number? We may have the service manual you can download free.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 20, 2008 | Goldstar MV-1501 Microwave Oven
The turntable keeps rotating when the dooe is open - Panasonic T994SFR
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
We have critical safety & disassembly info (including a how-to video) at our site, linked here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Jul 14, 2008 | Panasonic NN-T994SF Microwave Oven
Tiny Love Symphony Motion Deluxe Baby Crib Mobile Logo
100 people viewed this question
Top Tiny Love Baby Gear Experts
Dorel UK
Dorel UK
Are you a Tiny Love Baby Gear Expert? Answer questions, earn points and help others
