Question about Logitech Cordless TrackMan Optical Trackball
Cursor/pointer sliding down the screen at a fast rate. This just started it has been working fine.
I have a dell desk top. The point will continually slide down the screen all the way to the bottom.
Cursor and text jumps for dell inspiron 1150
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens. Type "Cursor blink" in the "Search programs and file" text box. A list opens. Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens. Click the "Speed" tab. A list of options appears. The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast." Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale. Click "Apply." Click "OK." The cursor stops flickering on the screen.
Feb 04, 2013 | Dell Inspiron Computers & Internet
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
Logitech m 705 mouse pointer flickering
A list opens.
Click "Apply."
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
I must have hit a button and now the cursor is showing up on the big screen off the projector but I only want to see it on my laptop while doing my presentation.
Hi renee_pott, "You can choose the "Mouse Options" in the Control Panel.
First, click on the -> Start button -> Control Panel -> Hardware and Sound -> Mouse ->
Mouse Properties -> Pointer Options.
Try one 'or' more options:
* Snap To, place a (Check in the box) !
* Hide pointer while typing !
* Show location of pointer when I press the {CTRL key} !
  • Usually the "Mouse" pointer by { Default }, is displayed during a slide presentation, and when the mouse is moved.
  • " Try pressing the {Ctrl + H keys to "Hide" the mouse pointer}."
  • Left-clicking on the "Mouse" button, will advance [forward] the slide show.
  • Pressing Ctrl + A keys, will restore the "Mouse" pointer.
!"Take a moment to rate the help."
Thanks paul7of9
Mar 23, 2011 | Computers & Internet
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
My cursor has turned into an icon that looks like a padlock, reducing maneuverability. Do you know how to get the regular cursor back? Thank you.
Hi, go to the "Control Panel," from the start menu, click to open, select in the Hardware & Sound category; "Mouse, next you can change the "Pointer" appearance, how "Fast or Slow..." the mouse pointer moves. "Rating the solution is appreciated, thanks."
Apr 03, 2010 | Logitech Marble Mouse Trackball
Blank screen with cycling colours (no BIOS; no POST)
Try running diagnostics. Tap F12 repeatedly on the dell logo till you get the boot device menu. Choose diagnostics. Go through it.
If it doesnt even pull up the diagnostics, you can follow this walkthrough from dell's website.
Oct 04, 2008 | Dell Precision M60 Notebook
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Jumping cursor
sounds like its a optical mouse, and you are probably using it on a reflective surface ie plastic mousemat, glass or along that lines, you will probaby find out it works fine on wood, or a a solid surface that aint reflective or a gel mouse mat.. :-) all the best John
Mar 11, 2007 | HP OPTICAL SCROLL MOUSE (8131)
Logitech Cordless TrackMan Optical Trackball Logo
16 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
