Question about Home
Toyota transmission 80 series land cruiser gear levers hi lo range
Want scematic drawing
  • 645 Answers
SOURCE: hi my 80 series land cruiser 3f cuts out when i
sounds like crank sensor is getting wet. Don't go through water until you figure out a way to protect it.
Posted on Feb 05, 2010
cantanko
  • 11 Answers
SOURCE: land cruiser vx turbo diesel 1990 80 series.
Track down Toyota publication RM184E - a search of the ih8mud forums is a good start to finding it.
Posted on Apr 25, 2010
SOURCE: toyota land cruiser 1997 80 series electrical wiring diagram
what are the colour of the wires for the unlock / lock for the central locking for a toyota landcruiser 1990 modle ?
Posted on Jul 04, 2011
Geekman
  • 32281 Answers
SOURCE: what type of Coolant should use for the Toyota Land cruiser 80 Series and how many litres?
You can use anti-freeze additive in the water of your radiator. It does not matter if you are not in a freezing cliamatic condition because it will still work and it contains an anti-corrosive component.
You mix this additive in the concentrations as per the instructions on the pachaging.
Posted on Jun 02, 2012
emissionwiz
  • 76691 Answers
SOURCE: Land cruiser 80 series.Hand brake wont adjust up.new shoes and pads.adjusted up with star wheel at bottom,light drag.lever on inside of hub got heaps of travel but not locking brakes on..
You need to adjust the park brake cable or replace it.
Posted on Jun 15, 2012
Toyota 80 series GLX auto landcruiser 1996 need head bolt torque a nd cam shaft torque settings
Torque setting Toyota Land-cruiser 80 Series 4.5 1995-98
Engine code: 1FZ-FE, 1HD.
Stage 1: 20 Nm (Start tightening bolts from center to outwards)
Stage 2: 39 Nm
Stage 3: Rotate each bolt by 90 Degrees.
Stage 4: Further rotate each bolt by 90 Degrees
Nov 22, 2014 | 1996 Toyota Land Cruiser
Adjust fan belt toyota land cruiser 79 series 2008 model
Hi there , there should be a adjuster on the alternator, unless it's a serpentine belt, if a serpentine belt then you will need a new tension bled idler, hope this helps.
Aug 28, 2014 | Cars & Trucks
Diff locks not engaging on 80 series landcruiser
I think these actuators depend on vaccuum, check that all the hoses are in place and intact, could also be the vaccuum pump.
Jan 28, 2014 | 1991 Toyota Land Cruiser
I own a BJ 72 1991 Toyota landcruiser , SWB 70 series I'm changing the oils in the diff's , what are the correct oils to use? Many thanks
We all use 80/90 weigth, but for more proteccion upgrade to 80/140w multigradre or even try a fully synteric brand, the higher the number more proteccion under severe abuse(heat)
Dec 05, 2010 | 1991 Toyota Land Cruiser
I have an 80 series landcruiser with A442F transmission, built 1993. It will not select 1st gear or overdrive. It takes off in 2nd and shifts to 3rd normally, 1st gear can be selected manually and changes...
It seems like your "2nd start" button is turned on. The 80 series LC has a button next to the shifter which allows it to start in 2nd gear. If the button is not engaged then there could be a problem with the circuit, but that is not common
Nov 01, 2010 | 1994 Toyota Land Cruiser
Land cruiser vx turbo diesel 1990 80 series.
Mar 12, 2010 | 1990 Toyota Land Cruiser
Hi my 80 series land cruiser 3f cuts out when i
Feb 05, 2010 | 1990 Toyota Land Cruiser
Can you tell me the type of my engine by number 0080682 on Toyota landcruiser 80 vx, 1995 4200 diesel turbo
Market JapanYear 05/1999Make TOYOTAModel LAND CRUISERFrame HDJ101
Vehicle characteristics
GRADE: VXL: VXL TYPE DESTINATION: JPN: JAPAN ENGINE: 1HDFTE: 4200CC DIESEL TURBO TRANSMISSION: ATM: AUTOMATIC TRANSMISSION GEAR SHIFT TYPE: 4FC: ATM, 4-SPEED FLOOR SHIFT COLOR CODE: 057
TRIM CODE: FG41
Jan 08, 2010 | 1995 Toyota Land Cruiser
Toyota land cruiser 1997 80 series electrical wiring diagram
Nov 08, 2008 | 1997 Toyota Land Cruiser
Home Logo
62 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
