Lines when displaying
Lines when Projector si running or in use
5 Suggested Answers
Marrie
  • 563 Answers
SOURCE: My projector has vertical lines on display;
Hi there
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Posted on Apr 10, 2008
projdoc
  • 2237 Answers
SOURCE: LP690 projector displaying strange lines
to adjust those mirrors, you need to power down, unplug, remove the top, remove the wires from the main board, remove the main board, adjust one mirror, reinstall everything, power up, see whatever difference it made, power down and repeat until it's fixed. it's quite a chore. if that's not the problem, you'll need to replace the optical engine (which isn't cheap) because they don't sell individual parts.
Posted on Aug 03, 2009
projdoc
  • 2237 Answers
SOURCE: dell 5100mp dlp projector - white vertical lines evenly spaced
clock and phase are off. go into menu and reset the settings to factory default.
Posted on Sep 02, 2009
  • 269 Answers
SOURCE: Projector will display image, but it has vertical
This likely a conncetion problem between the main board and the light engine. The added weight could be making the connection complete. You could open the projector and remove the ballast, power input board, and shield to remove the main board and clean the part that connects it to the bottom of the rear of the engine and then reseat the connection, BUT, this is a major task if you don't know what you are doing and is best left to a tech or living with the weight being on the unit.
Posted on Oct 29, 2010
What causes white vertical lines on dlp projector?
Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
Nov 05, 2011 | InFocus ScreenPlay 5700 Multimedia...
Projector will display image, but it has vertical lines running through the image. If a heavy object is placed on top of the projector, the lines disappear and will not come back.
Oct 28, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have an Infocus LP350. The image it displays has lines running through it, which consists of the text displayed, but offset and a bit jumpy. There are also some dark black lines on the right. How can I...
if you reset the settings to factory default and the text is still like that, you have a colorwheel issue and probably a dmd chip problem. as for the dark lines, if they are more of a shadow on the edge, the colorwheel is collapsing. if they are thin and definite, you may have a main board or dmd chip problem.
Oct 23, 2009 | InFocus ScreenPlay 5700 Multimedia...
Dell 5100mp dlp projector - white vertical lines evenly spaced
Sep 02, 2009 | Dell 2400MP DLP Projector
Vertical lines showing. it is an Optoma HD70
If the lines present in the menu when displayed this indicates device mounting troubles. Possibly loose in socket. If you change aspect of displayed image do the lines move, if they do, its an electronics problem, if they are constant, and nothing is displayed in the lines. Tighten device in socket, or seek professional service.
Jul 07, 2009 | Televison & Video
4 by 3 lines
noticed lines after watching 4by3 aspct ratio all day ,and then i switched to a hi def wide screen i could see lines on ether side of screen where the 4by3 asect ratio would end ,would not go away no matter how long i left the projejtor on displaying hd wide screen pcture ,this is an easy fix ,i just powered off projector and unpluged from outlet for 24 hour,s ,them pluged back in and powered on the projector and the lines are gone ,hope this helps someone out with the same problem ...
Sep 14, 2008 | Sanyo Televison & Video
My projector has vertical lines on display; what are possible causes of lines. Projector was dropped, I reinstalled lamp, lines went away for a while, now they are back.
Hi there
Apr 09, 2008 | Optoma EzPro 739 Multimedia Projector
Mar 09, 2008 | InFocus LP690 Projector, Factory...
Vertical Lines on the projector screen
When the vertical lines are displaying, open the projectors menu (by pushing the "menu" button). If the vertical lines affect the menu, it's a problem with the controller board and will need to be repaired. If the menu is NOT affected, it's probably a loose or damaged cable (Cable part# SP-DVI-A-R).
Oct 15, 2007 | InFocus LP70+ Multimedia Projector
83 people viewed this question
k24674
jasbo
jasbo
