Question about Bunn VPR Coffee Maker
Boils the coffee - Bunn VPR Coffee Maker
Keurig problems
Hi Vera
in my experience there are two types of coffee machines of this kind.
One boils the water in the spout that transfers the water from the water holder to the coffeepot
The other type boils the all the water in the tank before it run through the coffee. The latter type usually makes hotter coffee.
all the best
Kolbrun
Mar 07, 2014 | Coffee Makers & Espresso Machines
Coffee makers
Generally, coffee makers DO NOT have a separate "pump" that pumps any water of coffee around, but depends on a heating mechanism, that when the liquid is BOILING, causes pressure that forces the liquid to move to another location. If the heating coil is NOT working and getting the water/coffee hot enough to boil, then it will have to be replaced.
Feb 22, 2014 | Krups Nescafe Dolce Gusto
How to prime
I have NO idea what coffee maker you have but most do NOT have to be primed. Just put put water iun the top resevoir, coffee in the other and turn it on. THe water will boil and very hot water will boil up to the coffee in the coffee resevoir and through it.
Dec 31, 2012 | Coffee Makers & Espresso Machines
How hot should fresh perked coffee be from any coffee maker?
some people say that coffee can burn when you pour boiling water on the beans and recommend that you should add the milk first... I just let the kettle cool down until the boiling stop as well. as for espresso makers, water will boil and the gas (liquid to gas at boiling temperature) is pushed through the beans, so its rather hot and the beans doesn't burn.coffee should be as hot as possible!
Apr 02, 2012 | Coffee Makers & Espresso Machines
I recently bought an Avanti Art Deco 10 cup espresso machine and am disappointed that I cannot make HOT coffee with it. What can you suggest?
When the water boils in the bottom chamber the steam creates pressure and pushes the water through the grounds and into the top chamber. It's hard to imagine that the water going through the grounds is not close to boiling temperature unless you are using the coffee maker at high altitude where the temperature of boiling water would be lower.
Oct 26, 2009 | Avanti Art Deco 4-Cup Espresso Machine
Electric coffee maker no longer boils the water
As you explain i understood that heating element is in defect. Even if you don't find replacement in part DO NOT THROW IT. only remove electrical parts and you use it in direct heat , with gas or fire. buon apetit.
Sep 26, 2008 | Bialetti Moka Easy 6-Cup Espresso Machine
Use of warm water
Warm water is said to contain more impurities than cold water, like lead. Warm water takes more lead from your home plumbing, than cold water.
So it's not advised to use warm water for boiling...
Mar 27, 2008 | West Bend 13500 Coffee Maker
Bunn VPR Coffee Maker Logo
22 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
