Question about Garden
Pondxpert pondpush 6000 cleaning
How do you remove the outcasing to clear blockage in the pump. Are the screws removable of do I just turn them?
Krazytech
  • 725 Answers
SOURCE: Cannot get access to Water pump to clear it.
the sump is in the bottom center front. a retangle screen with a center filter should unscrew counterclockwise the drain pump is hard to access but if you want to let me know and I can walk you thru it..let me know if this helps
Posted on Aug 25, 2007
  • 7 Answers
SOURCE: Cleaning under floor nozzle window
make sure you removed the 2 screws closest to the front then lift up on the front end of the window sometimes its sticky but it will lift up. when putting it back on put the tabs on the back end in first then slip it down in the front , replace 2 screws
Posted on Jul 29, 2008
  • 39 Answers
SOURCE: Bissell pro heat carpet cleaner clear cover removal
just lift it up probably suction holding it
Posted on Jun 29, 2009
SOURCE: laser 72 wont fire up
I have just been inside my 72 for the same reason. Have you cleaned the burner pot and heat exchanger lately? If not it is time. What makes these things work is a burner mat in the bottom of the pot that will eventually go bad. if this occurs you must change it out, if it looks good ( looks unburned) and whole and attached to the pot then your problem is with the igniter or with the combustion sensor or a clogged fuel pot inlet fitting. The first thing I would check is the easiest, disconnect the fuel line from the inlet to the pot, remove the screws and pull it out, it may be kind of stuck in there so a little rotation usually helps. When out, hold one end up to a light and see if you can see unobstructed light through it, if not, clean it out using a piece of wire or if you have access to a set of acetylene torch tip cleaners use those until it is good and clean, re-install and try that. If no good I would disassemble the burner pot and heat exchanger and give it a good cleaning and inspection. If you go that far there are a couple of things to watch out for. First is when you go to remove the burner ring it comes off in a counter clockwise rotation, there are three pins set in the pot that hold it in place and if they are carbon encrusted it won't want to turn and DO NOT I repeat DO NOT try to horse it off, you will break the upper burner ring mounting arms and I have been told by my parts guy that they are unobtainable now. I speak from experience, I did it and had to weld it back together, no big deal if you can but if you have to take it to a welding shop it will cost you a few bucks. My suggestion is to take a large flat blade screw driver or better yet a brass or steel rod about a quarter of an inch in diameter and go down along side the upper ring and LIGHTLY tap around the lower ring to try to loosen up the gunk and try again, keep this up as long as you have patience and hopefully it will come out. If not you can send it to a Toyo repair station or horse it out and have it fixed. When you get the ring out the next issue after a good vacuuming and cleanout is the igniter unit, it will be stuck and if you cannot turn it you can heat up the burner pot around it with a propane torch until very hot and let it cool and repeat a few times until you can get it out, ( I suggest either taking the pot outside or running your shopvac over it when you do it) if you break the ceramic it will cost close to a hundred bucks to replace. If you are still with me, now for the cleaning part, if the burner mat has lifted from the bottom of the pot anywhere, it must be replaced and it will be burned up in the places this has happened. Give it a good scrape down and shining up with sand paper until no carbon or old glue remains and vacuum clean and wipe it with a solvent until clean. The new burner mat comes with a tube of adhesive and it takes about half of it to secure the mat down, a thin even coat is needed with no puddling, use a small one inch chip brush to coat it and brush it all in even strokes in one direction and then 90 degrees off to create a cross hatch pattern. Place the burner mat down and using your fingers press it into the adhesive until you have covered the whole mat, do not leave any piece unpressed. At this point you can clean out the heat exchanger by flushing it out with a hose outside, be warned, it is messy, lots of carbon and soot come out so pick a suitable location like a cleanable sink or out back somewhere. One other thing, when you go to remove the large gasket that seals the burner pot top to bottom, take piece of rigid paper, like a cereal box, and carefully slide it onto it and back on, don't pick it up by any means, it will crumble and you will have to spend another thirty bucks or so. I have learned most of this from my local parts guy and from the school of hard knocks, so I hope this helps. JP
Posted on Oct 01, 2009
SOURCE: Aquarius wf541. Am trying to remove pump filter to clean .
think yourself lucky my plastic broke when i was unscrewing it or tying to ended up cutting my knuckle open on the shard of plastic and water pumping out all over my kitchen is there somewhere that you can purchase the cap from and how do you get the broken one off???
Posted on Feb 23, 2010
WASHER STOP AND SCREEN WILL SAY f21
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the pump filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Reach in the pump impeller with your finger then turn it and inspect it for damage, restriction or blockage. Replace the pump if the impeller is broken or restricted and cannot be freed. Let us know if you need further advice.
Jan 21, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
Tip
The washing machine spins but will not drain?
To trouble shoot this problem please check this possibilities:-- The first thing to check out in this problem is check the draining line in the washing machine. Check if the drain line is got clogged or its getting blocked by any metal or dust object in the pump. Also check in between the inner clothes tub and the outer tub which holds the water. If the blockage is between the tubs, then it may clog the drain hose which is connected to the pump. If you notice blockage in the pump, then remove the hoses from the pump and clear the blocking material by removing it out.
But if the pump is clean and clear and hoses are also seen clean then the other part to check is
outer tub part, for that you will need to open the washer's main access panel and remove the rubber material hose connecting the pump .the hose is exactly connected to the bottom area of the outer tub. If you notice any blockage/clogging in that area you can remove it with the help of pliers.
If you are not able to remove the clog or if you can see but its seen in very inner area then you need to take the agitator out, after removing the agitator remove the top of the outer drum shield, and inner clothes tub. You will require some special tools to do the job in this case.
But if inner tub, agitator and other parts looks clean and clear then you need to check the drain pump. it may be leaking or it may be worn out and got loose.
This is the basic checking and troubleshooting you can do it yourself to resolve this issue of not draining.
on Mar 18, 2010 | Washing Machines
Cant find my book and keeps displaying F21
Jan 11, 2011 | Kenmore Front Load Washer
My precious Gaggia Classic machine has developed a "fatal error". It will not pass water through the shower head. I have tried cleaning, re-priming to clear air block, several times over. The pump appears...
Remove the shower, then the 2 allen wrench screws for the diffuser, careful do not loose the spring ad valve seat that is above the diffuser, now turn machine on to see if water will come thru, if water flows, problem is either screen or diffuser blockage, if no water then you need a stronger descaler because blockage is in the boiler, at the solenoid or from the pump. Most likely in the boiler, if you have a boiler gasket go ahead and open the boiler to clear the blockage.
Jul 04, 2010 | Gaggia Classic Espresso Machine
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
Access to Dishwasher Pump to check for Blockage
Turn off the power to the DW.
Remove the screws holding the door panel on(not the control panel screws).
Remove the "toekick" panel from the bottom of the DW. The pump will be in front of you.
Use a volt meter to check for power to the pump. If there is power,remove the pump and check for a blockage. If no blockage you can make a 120 volt test cord to power the pump to see if it works.
Jan 06, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Filter pump is stuck
As you are unscrewing it, at the same time try moving it from side to side, and then screw it back in again, then repeat the process, if it still will not come out, then your only noption is to remove the pump completely and clear the blockage that way.
Hope this helps.
Dec 29, 2009 | Bosch Washing Machines
I get a message saying check outlet pipes. If
If you need to clean the filter, then remove the lower rear cover.
Remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here, and check inside the pump as well.
Hope this helps with your prob, Good luck.
Thankyou.
Nov 26, 2009 | Hotpoint Ultima WD72 Front Load...
Will not drain
Check where drainhose connects to waste pipe for blockage. If OK, blockage likely to be in pump impellor.
Disconnect from power.
To access pump:
Open door and remove all bottom filters. Remove all water from inside machine. In the bottom of the sump on the left hand side, you will see a star screw- remove this screw and you can remove the cover it is holding down. Under this cover you will see the drain pump impellor (white fan blade). This impellor should turn relatively easily- check for blockages (careful for broken glass!!). It can be a bit hard to reach, but you need to get your finger right around underneath impellor to ensure nothing is stuck underneath- try flicking the impellor a few times to remove any obstruction from underneath. Once clean and free from obsruction, reassemble and test
Aug 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Feb 23, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
