Question about Bunn Coffee Makers & Espresso Machines
K cups explode - Bunn Coffee Makers & Espresso Machines
At the end of brewing it explodes water and grounds
Clean the Tubes that penetrate the Kcups. Use a needle or paperclip.
Oct 01, 2012 | Keurig B30 Mini Coffee Maker
Have had for 6 months with no problems. Recently have had coffee grounds both in the K-cup holder as well as the finished coffee in the cup. I used a different K-cup variety with same result. It's...
Hi, The bottom needle is plugged or missing...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 22, 2011 | Keurig Elite B40 Coffee Maker
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
K cup explodes
This happened to me with a B30. I called and they had me clean everything out thoroughly. at the very end the tech support lady explained the issue is with the kcups themselves. the ones with bulging tops have extra air in them that causes problems when brewing.
Mar 07, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Lg microwave exploded hot water on my face
It's rare, but obviously can cause serious injury!
Your manual should address this, or for more on what causes this, read this article.
Jun 14, 2009 | LG LMV1650SW Microwave Oven
K-Cup exploded
shoot it and get a good one
a german name doesnt mean good
most of them are just proctor silex or toastmaster , with a european name ,and higher price tag on them
the best one out there is still the Bunn, and the company stands behind them
Dec 13, 2008 | Keurig Coffee Makers & Espresso Machines
I have a SONY DSR PD170T the rubber eye cup and the diopter to which the eye cup is attached snapped out and got lost. I am trying to find and order a replacement? What do they call it? part#? thank you
You should order Eye Piece rubber under following part number...
" X-3953-896-1" CABINET ASSY, VF (REAR)
Here is exploded view of required part...
Above said part is available in Part Store on $110
Need further info, let me know please.
Thank you.
Dec 05, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Coffee Makers & Espresso Machines Logo
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
