Question about Kingwin KH-200U-BK 2.5 inch IDE HD to USB Black Aluminum External Enclosure
Windows 7 won't recognize USB mass-storage device KH-200U
I see the usb mass storage in the device manager but it does not show in windows explorer listing
Windows 8 x64 doesn0t show usb flash drive in windows explorer
It will only show USB devices that have been formatted. Have you tried going into the Computer Management, Disk Management to see if the usb drive is recognized? Can another windows PC recognize the USB drive?
Aug 17, 2014 | Electronics - Others
MY COMPUTER WON'T RECOGNIZE MY EXTERNAL HARD
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 03, 2011 | Toshiba Computers & Internet
How can i get an olympus w 20 driver under windows 7?
You shouldn't need a driver for windows 7, once you plug in the device it your computer should recognize it as a USB Mass Storage device just like it would with a USB flash drive which can be accessed by going to my My Computer then double clicking the icon for the USB Mass Storage Device. You can also download the user manual for this product from this page http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/.
Mar 15, 2011 | Computers & Internet
Cruzer SANDISK 4 GB ceased being recognized by Windows Vista
it may be necessary to uninstall and refresh the USB drivers. This requires Administrator permissions:
1. Open the Control Panel
2. Double-click System
3. Click the Hardware tab
4. Click the Device Manager button
5. Expand the Universal Serial Bus controllers section by clicking on the "+" symbol beside it.
6. Right-click on each of the hubs and devices you wish to reinstall (often named "generic hub" and "mass storage device") and select Uninstall
7. Reinsert the device and allow Windows to detect the device as if it were new
Mar 22, 2009 | Computers & Internet
Windows ME and Insignia
Insignia mp3 players can use the generic mass storage driver in almost any computer. Windows ME includes a generic mass storage driver. When you plug in the USB cord, two extra drive letters will show up in Windows Explorer. Songs go into the Music folder. For neatness: Make new folder for each artist and under each artist, make a new folder for each album.
Also slight chance the USB mode got off of Automatic in the player's options. Please do advise if it won't work, I will show you where to get the generic mass storage driver for windows ME and 98 if for some reason it isn't installed on your machine.
Jun 27, 2008 | Insignia Pilot MP3 Player
Connection
should have at least windows 2000 sp4 or xp sp1 as operating system. plug into usb port on computer while computer is turned on. computer should recognize and install it as mass storage usb device and assign it a drive letter. sometimes xp will recognize it as a panasonic mtp device. this doesn't matter, you can still drag and drop files on it through windows explorer file manager.
Nov 15, 2007 | Panasonic SV-MP020 MP3 Player
Sony Ericsson media manager software
What OS are you running? Does your system use USB 1.1 or USB 2.0? Try powering off your w910, wait a few seconds to make sure it completely cycles off, then connect your phone to your PC. It should turn on in USB (ie. 'Mass Storage') mode. If Windows attempts to Autoplay the device, Cancel the dialog. If Windows attempts to install any drivers for the device (or Vista prompts you to scan the device), Cancel the dialog(s). If you go into 'My Computer', is your phone recognized here (as a USB Mass Storage Device)? If not, the app is not going to recognize it either. Try disconnecting any other USB devices or memory card readers.
Nov 04, 2007 | Sony Ericsson W900i Cellular Phone
Kingwin KH-200U-BK 2.5 inch IDE HD to USB Black Aluminum External Enclosure Logo
23 people viewed this question
Top Kingwin Computers & Internet Experts
David Payne
David Payne
Are you a Kingwin Computer and Internet Expert? Answer questions, earn points and help others
