Question about Indesit IDCA735 White Electric Dryer 7kg, 16 Cycles
All lights flashing
The dryer works but the lights start to flash and won't go off until it is unplugged
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Bosch classixx tumble drier lights flash
The lights are flashing as an error code? what lights are lit/flashing, what rate of flashing etc? more information may help sort this faster
Mar 24, 2014 | Dryers
My maytag electric dryer won't start the light flashes off then on again
Remove exhaust. clean out lint. Remove back cover. Clean lint out of entire air system. Likely air block or overheating. If not, check back bottom of dryer for a white and black plastic thermal fuse. Unplug the 2 blue wires and electrical tape them together to bypass. Test dryer. If it works, replace thermal fuse before operating.
Jan 08, 2014 | Maytag Dryers
The clean button blinks, yet it won't start?
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes. I had the problem for several days and could not use the dishwasher not mater what tried until I did what I described above. Now I have to see how long it lasts.
Jul 24, 2012 | Kenmore 24 in. 15689 Built-in Dishwasher
Runs for little while then stops and has the code PAU on the display. I tried unplugging the cord, I reset the circuit breaker. Still the same and now it won't even start.
Try taking the control board out and check for burned off traces. Solder back those points and it should work again. Just did it to mine and now it runs again. Still flashes PAU though.
Jul 07, 2011 | Kenmore 84072 Electric Dryer
All the lights on front panel on my frigidaire FEQBB30DS0 dryer
Sounds like one of the buttons is stuck. You may have to replace the touch keys panel
Sep 04, 2009 | Dryers
Indesit IDCA735 White Electric Dryer 7kg, 16 Cycles Logo
53 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
