Question about Tricity Bendix WDR1040W Front Load Washer / Dryer
Bendix washing machine103w dial removal
Removing replacing dial
2 Suggested Answers
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Have a bendix duomatic wd1054b how do i put it on cold quick wash?
Not sure without knowing the layout of the dials but as a rule of thumb it normally works like this. The earlier the letter (A first) or the lower the number the hotter the wash so idealy it would be around F or 5. Hope thats of some help
Nov 09, 2011 | Tricity Bendix AW1000W Front Load Washer
My Tricity Bendix AW1400W washing machine will wash but not drain. I was told I have a faulty pump which I immediately changed but the problem still persists. Can you help?
If you have replaced the pump check that the pump is actually working the easy way to tell is to remove the filter and shine a torch up inside put machine on spin or drain and see if the impellor on the pump is rotating if not then the problem could be in the wiring or the main programmer is faulty.
Apr 14, 2010 | Tricity Bendix AW1000W Front Load Washer
How do remove the cover to expose the belt on tricity bendix aw1100s it seems sealed no back pannel
Your remove the front or side panels. Look for any screws to remove first then there will be spring clips that you pry on the side or front where you see it's put together. The spring clamps will release. You need to post a model number to get more specific info.
Oct 18, 2009 | Tricity Bendix AW1000W Front Load Washer
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Bendix Washer/Dryer WDB 1074T
Well well well - Welcome to the Bendix Club!
Here is the secret!
Push all 4 buttons in!
Turn on the Cold water only!
Set the first dial on 3 dots before the GREEN #12
Set the second dial to snow or cold
Set the third dial to one dot after the green 7....
If this doesnt work...the something is wrong with the machine!
Or email me.
Apr 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Bendix washer dryer 1054
the brushes need replaced in the motor by the sound of it
Feb 24, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix washing machine AW 1000 W
remove the rear panel 4 screws and you will see it on the lower of the drum.
Feb 09, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix 1000 washer
you need to replace the element. remove the rear panel and you can access it
Oct 22, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix WDR1040W Front Load Washer / Dryer Logo
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
