Numbers dim Numbers are to dim
Dim display
If you have the 12C Platinum, turn the calculator on. Press and hold the f key, then press the + key to increase the contrast.
Mar 09, 2013 | Office Equipment & Supplies
Numbers not complete on display
If the numbers are faded, dimmed or not even showing, the display control will have to be replaced. Thats the only repair for that issue.
Apr 25, 2012 | LG Dryers
Numbers not completed on display?
LED readout is getting very dim. I reset the computer but it's still dim, and only about half the numbers are visable.
Hi
The issue is with the display panel that is bad or the connection to the control is loose. TO check what is causing this issue you will have to take it apart and check the board, if bad then it should be replaced. Hope this helps...
Daniel
Jan 07, 2011 | Microwave Ovens
Need help in Special Formatting Number
Here is one solution. You might consider adding more robust error handling.
if the decimal numbers passed to the div function are multiples i will be a non-zero number of that multiple otherwise i will be zero.
Dim i As Integer
i = div(12, 0)
If i = 0 Then
'not multiple
' do this
Else
' is multiple
' do something else
End If
Function div(ByVal numerator As Object, ByVal denominator As Object) As Integer
dim n , d decimal
Dim result As Decimal
Dim remainder As Decimal
If IsNumber(numerator) Is True _
And IsNumber(denominator) Is True Then
If numerator <> 0 Then
n = numerator
d = denominator
Else
GoTo error1
End If
Else
GoTo error1
End If
result = Decimal.divide(n, d)
remainder = Decimal.remainder(n, d)
If remainder = 0 Then
div = result
Else
div = 0
End If
Exit Function
error1:
msgbox("Numbers must be non-zero numerics", , "Multiple check error")
div = 0
End Function
End Function
Aug 06, 2008 | Computers & Internet
Help me
this the code for your problem. by the way this for vb6.0
Sub CountCharacters(Text As String)
Dim iVowel As Integer
Dim iCons As Integer
Dim iNum As Integer
Dim iSpace As Integer
Dim iOther As Integer
Dim cnt As Integer
Dim sChar As String
For cnt = 1 To Len(Text)
sChar = LCase(Mid(Text, cnt, 1))
Select Case sChar
Case "a", "e", "i", "o", "u" ' And sometimes "y"?
' Vowel
iVowel = iVowel + 1
Case "a" To "z"
' Includes the first case, but VB matches the first case and stops
iCons = iCons + 1
Case "0" To "9"
' Numbers
iNum = iNum + 1
Case " ", vbTab, vbLf
' Space characters
' Not including vbCr as this will likely be dealing with Windows text
' and I only want to match one character for a newline
iSpace = iSpace + 1
Case Else
If sChar <> vbCr Then iOther = iOther + 1
End Select
Next cnt
Debug.Print "Text: " & Text
Debug.Print "Vowels: " & CStr(iVowel)
Debug.Print "Consonants: " & CStr(iCons)
Debug.Print "Numbers: " & CStr(iNum)
Debug.Print "Space characters: " & CStr(iSpace)
Debug.Print "Other: " & CStr(iOther)
End Sub
Feb 21, 2008 | Computers & Internet
Help me
Dim iNum As Integer
Dim cnt As Integer
Dim sChar As String
Select Case sChar
' Vowel
iVowel = iVowel + 1
Case "a" To "z"
iCons = iCons + 1
Case "0" To "9"
' Numbers
iNum = iNum + 1
' Space characters
iSpace = iSpace + 1
Case Else
End Select
Next cnt
End Sub
14 people viewed this question
 Grubhead
Grubhead
