Question about Refrigerators
Lg gr-l206eq it's dropping water under in a hose that goes trough a plastic tube
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
When the freezer goes into the defrost cycle the ice melts and the water is directed via tube to an area under the refrigerator where the heat from the compressor and condensor will cause it to evaporate. No need for concern.
Posted on Apr 01, 2014
SolutionGuy
  • 331 Answers
SOURCE: Ice Maker Water Supply Hose Freezes
Justin, the cause is a failed water inlet valve (behind the fridge, near the floor). The solution is to replace the valve.
The part number of your valve is 4389177 and it lists for ~$65.00. You can find one at a local appliance parts outlet or order it online. (actually, the valve kit comes with instructions =) )
Easy to replace. Pull out the fridge, unplug it and turn the water off at the wall. Now use a 1/4" socket or nut driver and remove all the screws holding that cardboard cover in place. Now remove the water hose from the valve and remove the 2 screws that mount the valve to the fridge. Pull the valve out and notice how it's wired and how the plumbing is done. Then simply wire in and put the tubing on the new valve and rebuild everything.
Job time? About half an hour. Good luck and don't sweat it, this repair is a snap.
Posted on Nov 05, 2008
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
heatman101
  • 43501 Answers
SOURCE: water leaking from top of plastic tube on back of
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jul 13, 2010
  • 4 Answers
SOURCE: LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Posted on Jan 16, 2011
  • 517 Answers
SOURCE: I have a GE Profile Arctica refrigerator - water
Good day!!!!
Refrigerators with a defrost cycle drain the melted water from the evaporator coils through a tube or a hole into a drip pan underneath the refrigerator. The water usually evaporates, but most times the pan is removable and can be drained. If this path of water is blocked at any point because the drain hole or tube is crimped or clotted with anything, it will back up inside the refrigerator area and try to find a way out, usually under the crisper drawers. To fix this, clear the obstruction in the drain tube. The drain pan at the bottom of the refrigerator can overflow or get old, crack, and develop a leak. Other times, mold can grow in the drain tube and clog it. Most refrigerators have an ice and/or water system built into them. This means that you have a waterline attached to the back of your refrigerator and it comes out as ice or cold water. Anywhere that water travels through the refrigerator and freezer can turn into a leak. To find the leak, you need to follow the tubes that carry the water through the appliance and make sure that all connections are tight.
Leaking containers or spills in the refrigerator can be misdiagnosed as leaks. First make sure that there are no puddles of juice, milk, water, etc. on one of the large capacity shelves.
I hope this solution will be helpful...Thanks for using fixya..
Posted on Aug 31, 2011
Freezer compartment drain trough misaligned, so hole at bottom of trough and the tube drain hose don't line up. Kenmore side by side refrigerator model 253.5567440N
These often never line up and shouldn't be an issue. The most likely problem is a slow/or blocked drain. Sometimes you can flush it with hot water and it will clear it but sometimes it needs to be removed and maybe flush it outside from the garden hose or in the laundry room. You would need to pull the unit out and remove the bottom cardboard cover to get to the drain tube.
Apr 07, 2018 | Kenmore Refrigerators
Water is freezing in the bottom drawer GEProfile bottom drawer freezer and leaking water on floor
Sounds like your drain tube is blocked in the freezer for the defrost water. The drain tube is in the back left or right corner and will have a drain trough under the cooling coils tilting towards it. That trough will probably have ice built up all over it. Once the ice is out you may need to force hot water down the drain tube. I use to use a turkey baster with a rubber hose on it to force the hot water down the drain tube. Its clear when you put water in the trough top and it goes down the tube freely to the drain pan under the refrigerator.
Feb 28, 2015 | GE Profile PDS22MHR Bottom Freezer...
Lg express cool water build up under crisper
Most fridges have a drain tube to catch water from frost free freezers there is a trough on the back inside with a tube that goes out the back the tube or drain hole are plugged
Feb 17, 2015 | LG Refrigerators
Where is the water condensation hose located in the Subzero BI-36U
Under each evaporator are drain troughs for each section, the tubes are connected to the trough and the drain into a pan under the unit, below the freezer section. I hope this answers your question.
Aug 02, 2014 | Refrigerators
My model RTW22 plastic hose crumbled that goes to
freon isn't poison. but should not be taken internaly. the tube is probably the cond drain tube and the bad liquid is algi/ water /dirt /grease/ sccume/ ect . replace the tube with a factory replace ment as it has special turn's in it . or use a 1/2 id hose and run it to the pan under neath .. now wasn't that easy **** ..
Dec 07, 2009 | Washing Machines
I have water puddling up under my Vegetable bins
Our fridge had the same problem with water under the crispers. My husband removed the slide out bottom out of the freezer section and exposed the galvanized trough that drains the defrost water into the drainage tube that goes to the tray under the refrigerator. Hallelujah! the galvanized trough was rusted through and allowing water to drip into the refrigerator instead of the drain hose. I have not found the trough on any parts lists so he is patching it with putty.
Oct 04, 2009 | Refrigerators
We are not sure what the tube coming out the back of the refrigerator does or where it goes for sure. I'm guessing it's a drain or cooling for the fan motor but still not sure. Can you help? Thanks (GE...
If you are refering to the 3/4 " tubing , it's the defrost drain hose from the drain trough to the drain pan under refrig . If it's the 1/4 " tubing , that goes from the water valve to the icemaker .
Aug 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
Water will not drain. Motor is working. Drain does not appear to be clogged.
GE has equipped many of their dishwashers with a crappy anti-syphon ball. The problem with this is that they often relocate and clog the drain. To fix it, syphon all the water out of the basin of the diswasher and remove the kick plate. Open the dishwasher and remove the 1/4" hex head screw behind the food screen and remove the spray arm by prying the plastic clip on the back side (be careful not to break it). Then remove the two 1/4" hex head screws in the plastic basket and remove it. Remove the two screws that hold the dishwasher to the countertop and slide the dishwasher out. There is a large manilla colored hose with a huge hose clamp on it. Have plenty of rags on hand because this part gets messy. Remove the hose clamp and pull this area open. A small white plastic ball should roll out. Replace the hose clamp and slide the dishwasher back into place (clean up all the water that escaped first, and make sure you have turned off the power to the dishwasher before beginning). Drop the ball into the small tube on the left side under where the plastic basket goes. Installation is reverse of removal.
Aug 03, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Hello, we have a three year old LG GR-359SQ Fridge freezer. Firstly, everything works fine with the unit but at the bottom of the freezer compartment is a 30cm x 30cm by 10mm deep trough that in a space of...
Try adjusting the levelers on the bottom I like to see 1/4 bubble on a level if you don't have a level no problem just so it slopes to the back. good luck Tom
Jul 02, 2009 | Freezers
LG Dehumidfier
When you install the drain tube, be sure that it is placed into the drain hole in the dehumidifier. You then will be able to "latch" the tube at the hose end by lowering onto the outer hole opening. This maintains a tight connection and the water will drain properly.
Jun 17, 2008 | LG LD65EL Dehumidifier
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
