Question about Panasonic KX-FAW505 Waste toner collector, Waste toner collector Consumable Type, Laser Printing Technology, 1 Included Qty, Up to 32000 pages Duty Cycle, For use with KX MC6020, MC6020HX, MC6020PD, MC6040, MC6255, UPC 037988840519 KXFAW505 KX-FAW505 KX FAW505
Empty the Waste toner collector mc6020 - Panasonic KX-FAW505 Waste toner collector, Waste toner collector Consumable Type, Laser Printing Technology, 1 Included Qty, Up to 32000 pages Duty Cycle, For use with KX MC6020, MC6020HX, MC6020PD, MC6040, MC6255, UPC 037988840519 KXFAW505 KX-FAW505 KX FAW505
  • Panasonic Master
  • 6,161 Answers
Just order a new waste toner box and replace see the website for operator instructions
Posted on Jun 13, 2015
I keep getting an error message stating to install a waste toner box and close all doors.
Printers usually have a waste collector where excess toner is collected. Obviously, yours needs to be changed.
Mar 07, 2016 | Konica Minolta Bizhub C452 Color Copier,...
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Can I empty the waste tone or do I have to replace it?
Toner is very fine and the dust in the air can easily enter your lungs. Standard vacuum cleaners will not contain toner and it will go into the air. Sometimes you can empty the containers but be warned that many designs have an section that rests in an optical sensor and that section is almost impossible to clean. Waste toner collectors are usually not that expensive.
Dec 19, 2015 | Brother MFC 9840CDW Color Laser...
Reset transfer unit epson c3800
You can't - at least not without some specialised kit and knowledge.
The transfer belt also has a waste toner collector, so even if you just reset the chip, the waste toner collector would soon overflow, resulting in waste toner all over the inside of the printer (because there would be nowhere for it to go.
Refurbished transfer belts (and fusers) are available via THAT well known internet auction site.
Jan 07, 2014 | Epson Aculaser C3800 Transfer Unit
Epson C2600N waste toner collector full warning, after replacing the collector
Victor_Ott:
You have emptied the waste toner bottle, now you have to tell the printer that you have done so. The waste toner collection system has a "latch" (electrical signal) that is tripped when the bottle is full. it may be a pressure sensitive switch under the bottle or a photo-sensor that senses the toner level when full. I don't know the sequence of events to "switch" that latch. Usually on the larger machines it is a series of keystrokes on the printer's keypad, starting with turning the machine off and holding down a series of keys while turning the machine on (known as the "maintenance mode". Once you are in the maintenance mode, you can "trip" that "latch" to let the copier know that the toner collection bottle has been emptied.
Sep 22, 2012 | Epson AcuLaser C2600N Printer
My Samsung CLT-W409 has showing a problem it says: waste bin error what can i do to solve this problem?
Open the door of the printer and on the left side you find the toner collector,get out and empty the collector.
May 05, 2011 | Samsung CLP 315 Laser Printer
Waste toner gets full before toner runs out
Actually, the waste toner should get full sometime before the regular toner runs out in laser printers that have several toner cartridges compared to the single waste toner reservoir.
You can dump the toner reservoir out and avoid buying the empty waste toner 'reservoir.'
I did this on my Brother Laser printer and saved about $30 or so for an empty plastic waste toner bottle or jar.
If this is the way the Kyocera-4020DN is, then I would put the waste toner, which is just that, waste, and put it into a plastic zip loc storage bag and throw it away. Don't breath the toner.
Good luck on this repair.
Jul 19, 2010 | Office Equipment & Supplies
I get a message waste ink abrorber full
Check your manual for the location of the waste toner collector, remove and empty or replace it.
Mar 19, 2010 | Canon Office Equipment & Supplies
Canon Copier 6025
The Waste Toner is located in the the drum unit it self. You need to remove the drum unit & on the top of the drum unit is a white or clear rectaular cap. You need to open it carefully and vac out the toner in side the unit. FYI if you are empting the waste toner the drum is just about worn out... Good Luck
May 18, 2009 | Canon NP 6551 Black and White Copier
Estudio 3511 empty waste toner problem
Hello sir;You have to empty waste toner container, it located at the end of the drum unit.
Jan 05, 2009 | Toshiba Estudio 200L Copier
Panasonic KX-FAW505 Waste toner collector, Waste toner collector Consumable Type, Laser Printing Technology, 1 Included Qty, Up to 32000 pages Duty Cycle, For use with KX MC6020, MC6020HX, MC6020PD, MC6040, MC6255, UPC 037988840519 KXFAW505 KX-FAW505 KX FAW505 Logo
150 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
