Question about Garden
Rolux dynamo powertorque electric lawnmower wont start
Machines hums as though power is being supplied but wont kick in and start.
kf4rwe
  • 25 Answers
SOURCE: Intertherm model e3eb020h electric furnace won't start just hums
Check fuses. one may be blown, and the other one not, Therefore you are getting only 110V to a 220v circuit.
Posted on Dec 03, 2008
localwonder
  • 6784 Answers
SOURCE: does not start
Hi, check the following trouble spots below. you will find the issue in one or, all the areas stated.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch/door latch
The washing machine may not function if the lid switch or door latch mechanism is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control or control Board and start switch as well.(You can test the continuity or, resistance level of the Lid/door switch with a multimeter(ohm).
Posted on Oct 09, 2009
buffalonyman
  • 1865 Answers
SOURCE: wont restart after power surge & verifying power supply restored
The control board may have been damaged by the power surge. You should install a surge protection device on the incoming power line, thereby protecting everything in the home from damage.
If you need help with this, go to the following website and fill out the form, be sure to include an email address
http://taeckertindustries.com/prod04.htm
Posted on Nov 17, 2009
kel1guy2002
  • 3740 Answers
SOURCE: need to replace to old blade with a new one on a
Disconnect the spark plug wire and ensure that the plug cap is some distance from the spark plug.
Remove the center cover cap (Pry off) and then remove the mounting bolt by turning it Counter clockwise while holding the blade to prevent rotation. Pull off the old blade and remove the center hub housing from the old blade. Transfer the center hub housing and install the new blade. Tighten the bolt CLOCKWISE while holding the blade until it is tight. Make sure you use a 6 point socket! Using a 12 point socket will result in the socket slipping and personal injury.
Re-connect the spark plug wire and your ready to mow again.
Thanks for using FixYa.
Kelly
Posted on Mar 07, 2010
SOURCE: washing machine has electric power supply but
There is an electrical short which needs professional service. It's dangerous -- do not try to operate it -- could be lethal.
Charlie
Posted on Feb 27, 2011
My Frigidaire fex831fs4 washer motor hums but wont start.i took belt off.still hums no start even when timer is not set to run.if I close lid motor hums then kicks out then it trys again.thanks 4 help
I appreciate your post, Mike!
Based off what you have described your Frigidaire washer motor will hum and not start. In order to test each component you would need to have the proper electrical equipment. I would recommend contacting a professional technician for proper repairs. They will have the necessary equipment needed to complete your repair. Hopefully this is helpful. -Matt
Aug 31, 2015 | Frigidaire Dryers
Rolux generator
put a bunch of nuts and sheet metal screw in the tank add muriatic acid just to cover loose metal. shake on all sides for 1 minute each side. Prevent leaking and wear rubber gloves and glasses. the rust will be gone.
Empty tank of all loose metal....reuse the tank
Nov 20, 2013 | Garden
Pentair dynamo 340210 was running fine, cleaned out skimmer basket turned it back on and all it does is hum. The impeller is not clogged and turns fine by hand. Any solutions?
you have probably hit a dead spot on the motor - try turning the motor by hand and then turn it on - maybe it will kick it.
dangerous to do it while the power is on but some people have had luck doing the same thing while the power is turned on.
US Parts Center
Aug 21, 2011 | Dynamo ABOVEGROUND POOL PUMP - 1HP -
My pump kicked the breaker, shutting off power to the heater and making the pipes freeze after letting it sit for awhile and hopefully unthawing the pipes i turned the pump back on it made a humming sound...
See if you can turn the impeller by hand...if you can then the motor start capacitor has probably bit the dust..this will throw a breaker if you leave it on too long...motor capacitors are available from appliance parts stores and some electrical supply warehouses
Jan 18, 2011 | Plumbing
Motor feels bound and hard to turn... DYNAMO PaFab Pool Pump.. motor can be turned by hand.. but just hums when turned on..
If there is a capacitor on it, you could replace that. If there is no capacitor the starting switch is probably broken. If you are not used to working with electricity, either have someone qualified work on it or...BE CAREFUL!..God luck...Lee
Sep 10, 2009 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
Bought a used Martin Logan Dynamo subwoofer a couple days ago and have a very loud hum when the ac cord is plugged in, even if the speaker is not connected to an audio source. The "hum" can be heard in any...
Neither the amp or the sub have grounded power cords.
I have discovered the ML Dynamo takes about 30 minutes to switch to standby in auto mode.
With speaker level inputs connected to the Onkyo A807 amp, both units powered from the same wall outlet, Dynamo sub on Auto, the sub hums for about half an hour after the Onkyo is switched off, then the sub goes quiet. Not so good.
I connected a bonding wire between the two units on 3_7_09. If I smoked some old audio gear I could just look at that as an opportunity, right?
Works fine. Now I have the ML powered from the wall and working normally.
Jun 30, 2009 | Dynamo MartinLogan Subwoofer Speaker
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Dec 03, 2008 | Intertherm Heating & Cooling
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
