Question about InFocus X6 DLP Projector
I want remote for x6 DLP Projector - InFocus X6 DLP Projector
Lamp ballast
www.shopjimmy.com There you can find that out.
Nov 06, 2013 | InFocus X6 DLP Projector
How to change infocus x6 model without remote
try mo po icheck ung lens nyan o kaya po sa cable
Sep 04, 2012 | InFocus X6 DLP Projector
My x6 infocus does not react to the remote control
sometimes there is a switch near the battery or on the bottom of the remotes to disable it. otherwise some projectors have an option in the menu that you need to turn on to be able to use the remote, it should be under IR options
May 11, 2012 | InFocus X6 DLP Projector
Menu from Projector keeps popping up. it will clear away when we click MENU button but then within 5 seconds, it will pop up again. we are using ACER XD1150 DLP PROJECTOR. would appreciate any...
hi,
Check is the remote transmits signals for menu at any time.
to check this after clearing the menu remove the battery of the remote. if the menu didn't po pup again , the remote need cleaning .
If the menu pop up again then, you have to check the menu button (push button) on your projector.
ok
Feb 21, 2011 | Acer XD1150 DLP Projector
There is no sound
HI
Please try replace of audio cord from player to projector.if cord is o.k then some thing wrong with Main boad
Thanks
For
M.R. Mumbai & Dubai
Sep 02, 2010 | InFocus X6 DLP Projector
My InFocus projector is making alot of noise
could be either the colorwheelor one of the fans. checkthe fans for obstructions. otherwise, replace the colorwheel.
Feb 18, 2010 | InFocus X6 DLP Projector
Where can I get a replacement remote for a XR-10X-L DLP projector
The link below contains the original replacement remote control for your unit.
Sharp XR10XL Replacement Remote Control
Jan 07, 2010 | Sharp XR10XL DLP Projector
What is usually the cause when a projector overheat?
restricted air flow. either one of the fans are not working, the vent is blocked, or the projector is filled with dust. so, check the fans (if they are slow, replace them), make sure nothing is close to the back or sides, and blow out the dust with canned air. if it has overheated a number of times, you may need to replace the thermosensor.
Oct 21, 2009 | InFocus X6 DLP Projector
Remote control for Canon LV X6 Projector
what if it still doesn't work out? is there anything else that i can do, thank tou
Nov 29, 2007 | Office Equipment & Supplies
InFocus X6 DLP Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
