Question about DeLonghi KBO3001 Cordless Electric Kettle
Kettle does not turn off automatically
Is there a steam hole that requires 'unblocking'?
Kettle bosch twk7901gb will not switch off
Make sure the steam is allowed to warm the bi metallic switch.
Apr 10, 2016 | Bosch Kitchen Appliances - Others
Russell hobbs problems
Hi Naomi,
please check the manual.and see if it is has a small hole or opening in kettle to go to outside of steam.
your one must be blocked .
regards.
nuwan
Jan 13, 2014 | Toastess Cordless Electric Glass Kettle...
Has stopped steaming
take the head off and see if the hole is blocked if so get paper clip and see if you can unblock the hole ,this link is the manual
http://www.sharkclean.com/manual/S3501_instructions_READABLE_04-22-2009.pdf
Jan 01, 2013 | Shark S3501 Steam Pocket Floor Mop With 5...
Kettle does not automatically shut off even when water is at above minimum level and boiling
I think that standards require an auto-shutoff on electric pots to keep the component from softening down. You could override the shutoff by either taping over the switch or utilizing an elastic band. You can check deep details on electric kettle review sites.
May 15, 2010 | Chef's Choice 677 Cordless Electric Kettle
Kettle not switching off after boiling so carrys on boiling untill you turn it off
To state the obvious, the steam sensor has failed. Unless you are quite adventurous, and confident dealing with electrics, there's nothing for it but to get a new kettle (unless the kettle is still within warranty, in which case you should be entitled to a replacement of course).
Oct 11, 2009 | Morphy Richards 43025 Electric Kettle
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
The tea kettle stopped whistling...
I could be that you have some debris in the hole. Try running a pipe cleaner though it a few times and see if it helps.
Mar 18, 2009 | Kitchen Appliances - Others
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
How to fill water in black decker steam iron
Hi there
Place your iron in an upright position like shown bellow
Take a jug of water from a kettle(Kettle water prevents blockage caused bu dirty water)
At the top of the iron you will find a hole
Pour the water into that hole and your iron is now ready for use!
Jun 27, 2008 | LG KU990 Viewty
Kettle
Here is a link to instructions for a commercial kettle.
It tells how to clean and maintain.
I hope it helps.
http://www.blodgett.com/Literature/Manuals/Steam/KLS-E%20&%20KPS-E-man.pdf
Feb 08, 2008 | Market Forge Electric Table Top Kettle - 4...
DeLonghi KBO3001 Cordless Electric Kettle Logo
47 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Shehu Pro
Shehu Pro
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
