Question about Maytag MVWC400XW Washer
NEED TO PUT INTO DIAGNOSTIC MODE
NO TECH SHEET
Kenmore High Capacity Dryer won't go into diagnostic mode
faulty touch panel key pads are the most likely suspect. Prior to diagnostic you should be able to enter the fault code memory to reference what fault codes are stored in the main board. Pleazer Appliance...
Apr 23, 2014 | Kenmore Dryers
Lavatherm 58800 e62
This machine needs to be put into diagnostic mode and check for the thermostat. It's not that complicated if you have the tech service sheet that you can find in the machine.
Dec 23, 2013 | AEG Dryers
Code fault E50
Need to put into self diagnostic mode and test the components. You can find the tech repair sheet in the machines that will tell you both what the error code is, how to test it, and how to replace it.
Dec 21, 2013 | AEG T57800 Electric Dryer
My frigidare affinity dryer is only starting on delicates and touch up, can you tell me why this is happening?
Hi.
If machine runs only in low heath cycles, then there is a problem with timer control, low heath selector, or heating assembly (cycling thermostat).
The first thing to do would be locating the tech sheet. The sheet is tucked inside an envelope located inside the control panel assembly. In the tech sheet you will find instructions to run a diagnostic cycle. The diagnostic cycle will return an error code that will help locating the fault.
With different Frigidaire Affinity dryers you need to press and hold Pause Cancel and SELECT for about ten seconds, then leave, put selector to NORMAL, temperature selector to HIGH HEAT and touch START to run the diagnostic cycle. The procedure for this specific model is described in the tech sheet.
Regards.
Ginko.
Nov 19, 2011 | Dryers
My frigidare affinity dryer is only starting on delicates and touch up, nothing above that
Hi.
With different Frigidaire Affinity dryers you need to press and hold Pause Cancel and SELECT for about ten seconds, then leave, put selector to NORMAL, temperature selector to HIGH HEAT and press START to run the diagnostic cycle. The procedure for this specific model is described in the tech sheet.
How do I engage diagnostic mode?
The tech sheet inside the control panel explains how to do this but I will include an abreviated procedure here.
To enter Diagnostic Mode:
  • Turn power off at the console
  • Press and hold the wash temperature down then press thepower button. The machine should give two short beeps.
  • The different levels of information can be extracted by using the spin speed up or the spin speed down buttons.
Sep 23, 2009 | Washing Machines
Getting error E3
3E == overcurrent detected at the motor.
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board. Hope this helps.
Jul 16, 2009 | Maytag Neptune Washer
GU1200xtks0 Blinking Lights
Try pressing heated dry, normal, heated dry, normal keys within 6 seconds. All lights should come on and the machine should enter diagnostic mode. If this does not work remove the 2 screws that hold the toe panel on at the bottom front of the dishwasher, attached inside you will find a tech sheet that tells you how to enter the diagnostic mode. Once you get it in diagnostic mode let it do it's thing, will take about 20 minutes total. At the end the control will be reset. If the fault comes back then troubleshoot according to the tech sheet, or call for service.
Feb 20, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Maytag washer 3e fault code
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag MVWC400XW Washer Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
