Question about Kenmore 15864/15862 Top Load Washer
Agitator came apart while doing laundry
While doing a load of laundry the top of the agitator came off....the fabric softener dispenser and the piece underneath that...not sure what it is called....it covers the gearcase shaft. How do I get it back together...I've tried and it keeps coming apart.
The agitator is loose....I am able to pull it up at least 1.5 inches....is this normal??
  • animes30693 Jun 16, 2009
    I inspected everything and nothing looks broken....I checked to make sure the bolt was snug and it was.
    The model # is 11024832200.
    Thanks.....I appreciate your help!!
    President:
  • 3,113 Answers
There is a bolt that holds this together that screws into shaft. Is the upper agitator broke? Or the ratcheting part in the center? Give full model number to further assist you.
Posted on Jun 16, 2009
  • honeymokey
    honeymokey Jun 16, 2009
    Go to the appliance parts store and get an upper agitator repair kit. Something has to be broken. Kit comes with o-ring seal bolt seal ratcheting parts and what they attach to plus thrust bearing.
Fabric softener dispenser will not stay on agitator
Hello friend, thanks for the post!
I understand that your fabric softener dispenser is not staying on your agitator. Would you be able to provide me your model number please? With that information I can research any further questions you may have. You can normally locate your serial tag (which lists your model number) on the upper front interior of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. I look forward to your response.-Matt
Jul 28, 2014 | Frigidaire Washing Machines
Washer wont agitate or spin
Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Aug 03, 2017 | KitchenAid Washing Machines
Fabric softener ends up around rim of washer.
When you say you've cleaned both parts - have you poured hot water in and seen it actually drain out of the top peice while it was removed from the agitator? Have you poured hot water into the agitator with the top peice removed and seen it drain out of the holes? If not, repeated flushing (of the agitator) and soaking (of the top peice) with hot water as needed until is drains may be required. Until you can get water to drain out of both peices alone, it will work automatically. Once you have the water draining try again with a regular load of laundry and fabric softener. If it still doesn't work...
Since you've cleaned both parts (the non-removable and removeable top portion) of the agitator - it would suggest that the fabric softener dispenser's actuator inside the agitator is not functioning properly. The fabric softener isn't being released in the rinse (or at all really) and as a result of the centrifugal forces during the high speed spin cycle - it is causes the fabric softener to move up the sides of the dispenser and spray out of the top of the agitator onto the rim. This may be caused a mechanical or electrical failure in the washer or washer control. It will continue to work like this until it is fixed - so I suggest that you do not use the dispenser.
You will likely need to have the washer professionally serviced to have it begin working again. You can save the repair costs and either add the fabric softener yourself during the rinse cycle - or use "dryer sheets" in the dryer instead.
Feb 05, 2013 | Washing Machines
The top part (not the fabric softener cup) of my Roper top loading washing machine came out when I took a blanket out of the machine. I tried reassembling the agitator, but, it doesn't fit correctly. ...
If this is the split agitator (two piece), the top part should not come off without tools. The part of the agitator that receives the fabric softener dispenser has a clear plastic cap that comes off to reveal a bolt. If this is the piece that you have described, something broke.
The bolt in the picture must be removed to release the upper agitator from the machine.
Is this the part that came off? If so, the bolt came off or the upper agitator is broken.
Jul 11, 2011 | Roper RAS8445KQ Top Load Washer
REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Nov 03, 2009 | Maytag PAV2300 Top Load Washer
I am trying to remove agitator, can you explain how to do/
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
Some versions of top load Kenmore washers use a two piece agitator.
1. Remove the fabric softener dispenser.
2. Using a short screwdriver, pry off the top cap of the upper agitator.
3. You may see a 1/2" square drive nut. Remove the nut and pull the top agitator off. Underneath it are the agitator dogs.
4. You may see another bolt that holds the lower agitator onto the main transmission agitator shaft. Remove the bolt and pull the lower agitator off.
Oct 20, 2009 | Washing Machines
I can't get top part off the agitator
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
If you have a 2 part agitator assembly (Fabric softener dispenser, top agitator and main agitator)
First, push down on the ring around the bottom of the fabric softener dispenser and lift it off the agitator.
Pry the top cap (a short screwdriver into the slots in the cap works) of the top agitator.
Looking into the center of the top agitator, you'll see a plastic piece with a 1/2" square hole. Using a 1/2" socket set extension, unscrew the piece carefully. You might have to hold the bottom agitator in place while you do this.
The top agitator pulls up.
You'll see a bolt and screw holding the bottom agitator on. Carefully unbolt this one and the entire bottom agitator will pull up.
Sep 27, 2009 | Washing Machines
How do you remove an agitator from a ge washing machine. I removed the fabric softener dispensor, but there is a clear plastic cover underneath that cannot be removed.
Well, first we have to determine if it is a Whirlpool washer or a GE washer, as they are quite different. I'm going to assume its a Whirlpool. When you remove the fabric softener dispenser from the center of the agitator, there is an opaque plastic cover under that. It must be removed to reveal the agitator retaining bolt underneath it. They can be quite hard to get out sometimes, you just have to be persistent. If you break it, it is replaceable as a separate part, part number W10074580.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag MAV7000 AWW washing machine agitator won't spin freely.
When you grab the fabric dispenser and move the agitator "counter "clockwise you should hear the rachet noise,once you try and move it back "clockwise" the fabric dispenser should slide inside the agitator and the agitator should NOT move.
Apr 02, 2009 | Maytag Atlantis MAV7000
How to pull apart fabric softener dispenser
MOST DON COME APPART SOME HAVE A BLUE RING PUT IT UP AND PULL THE SOFTERNER UP AND PUT IN THE WASHER RUN A LOUD SMALL AND HOT WATER AND LET IT CLEAN IT SELF IN THE WAHSER
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
129 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
