Question about Craftsman Garden
Change bearing greenfield piecemaker shreader
The bearing has over heated i cant remove the grub screw on the main shaft
  • 6 Answers
SOURCE: How to remove gear from arbor shaft on cut off saw?
The fact that there is no screw suggests its a push fit. Without knowing the machine, I am taking an educated guess, but suggest you will need a hydraulic press.
Posted on Mar 04, 2009
  • 409 Answers
SOURCE: How do you remove the impeller and mechanical seal
The impeller is screwed on to the shaft, you need to pull the cover off the end of the motor opposite the pump so you can hold the shaft to keep it from turning. The impeller should unscrew with just hand pressure, most are a standare SAE thread and turn counterclockwise to remove. Hope this helps.
Jimmy
Posted on Mar 13, 2010
  • 123 Answers
SOURCE: Hilti TE 10 stopping and starting, suspect bushes
To get to the brushes all you need to do is remove the 3 screws on the back handle of the tool. No need to seperate the motor from the gear housing. Pull the back cover off and you have access to the brushes
Posted on Sep 16, 2010
Testimonial: "Thanks for taking the time to help, using your answer I've now solved the problem."
  • 713 Answers
SOURCE: Simpson enduro 702. I want to replace the bearing
Hi Bevitt just read your posting.Now are you referring to the main seal of the tank and the bearings for the main shaft?Also where is this 'large circular white base' located,is it under the machine or in the tub?Sorry to ask you this question but I am having trouble picturing what you are describing.Please reply with additional information and I am sure I can help you rectify the problem.Looking forward to your reply.
Posted on Oct 14, 2010
mech1920
  • 22 Answers
SOURCE: how to remove the inner bearing front left axle shaft
small screw driver or pick just comes right out
Posted on Nov 28, 2011
How can I the grub screw in the top shaft of my Elna SU when it is damaged; the one you have to remove to withdraw the main shaft in order to replace the Pinion (Elnagraph).
Hi Peter, I would suggest that you join the Yahoo Group called elna Heirlooms and then search their threads there. Many of their members are familiar with the SU and do their own repairs and share their knowledge.
Jun 19, 2016 | Elna Sewing Machines
Take apart olympus sz3060 microscope head
I will try to help, but ?
Why do you need to do this would be the first question ?
A lot of maintenance can be carried out without dismantling the unit.
Their are also lots of special techniques for free jammed parts without a full strip down ?
email yvonne@ukmicroscopy.co.uk and let her know what the issue is and the engineers will discuss it with you for FREE before your start ( IF you want to of course)
1st Rule : As a general rule, everything is fixed with either grub screws or screws, most are small and some are hidden under caps or labels
2nd Rule : DO NOT use cheap or inappropriate tools : you will damaged the instrument and then someone like us has to drill them all out at substantial cost.
3rd Rule : LInt free high quality cloths, propanol only for glass and lenses.
4th Rule : TAKE PICTURES of everything as you dismantle it so you have a visual record of the project
Lower housing around the bottom lense will normally screw off, however it will be secured with grub screws or screws so you will need small alan keys or screwdriver to remove. They screws do not have to be taken out completely.
The eyepiece tubes will also screw out , but again check for screws and grub screws acting as locking nuts.
The main focus knobs, normally have a plastic cover at the end that needs to be taken off and you will find compression fittings with either a grub screw , knut or screw . these need to be removed and pulled off, gently but be firm.
The main body should be screwed : Remove again with a high quality x driver (Phillips) (It will not be a PZ head for the screw)
Question is now what ??
Hope it helps
Feb 12, 2015 | Olympus Sz3060 Stereo Microscope Sz30 Head
Impeller shaft bearing replacement behind shaft pulley
be sure all fasteners are out (bolts set screws etc)
try pb blaster spray
then its heat it up time
good luck
Feb 07, 2015 | Garden
Fisher and Paykel GW712AU.I replaced the main shaft seal and bearings.Now the shaft with the wash bowl attached slides down through the seal,top bearing, spacer and lower bearing causing the motor to
Hi I just read your post.
It sounds like you have got the shaft upside down.
Large nut for the shaft goes on at bottom bearing & put your seal in last.Make sure you put enough grease on the lip of the seal.
Feb 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
How can i remove the spinner drum from a defy twinmaid 920 (twin tub)? please help?
1)You have to tip the machine on it's back and remove all the screws from the bottom grey cover.
2)There are 4 screws securing the drain plug at the back. Remove these as well. Gently pry off the bottom of the machine.
3)The spin motor sits on four spring mounts. Undo the 4 screws from the top of the mounting plate.The motor shaft is not screwed to the drum. Slide the motor out of the drum shaft.
4) Once free, there are 2 X 10 mm bolts that lock in 2 grub screws on the shaft. Loosen these an remove the grub screws and remove this coupling off the drum shaft.
The drum is now free to come out the top of the machine.
Hope this helps
Jun 16, 2012 | Washing Machines
Top blade wont spin help.
the top blade should not spin unless the main rotors are turning as this gives the copter forward and sideways movment it should be secured with a small grub screw to the main shaft
hope this helps
Aug 08, 2011 | RC Remote Control Rc Helicopter
How can i remove the fan barrel from the head unit to clean it
with care. first remove the screws holding the covers, you will find them behind two or three small caps near the louvers and maybe under the filter cover. Completely remove the plastic face. Remove the screws holding the coil in place. You can only remove the left hand end as the right hand is connected to the pipework. remove the grub screw holding the fan barrel onto the motor shaft. Remove the screws holding the left hand bearing in place. At this point you should be able to withdraw the fan barrel. Take very real care how you handle the coil, for if you kink the pipes your machine will no longer perform without some major surgery. While the unit is dismantled , try cleaning inside the machine, removing dust and mould. Reassemble in reverse order
Mar 05, 2011 | Fujitsu 12C1 Air Conditioner
MSZ A12NA the inside fan is making noise how do i
It's a quite complicated procedure but i'll try to describe as best i can.
Below the air outlet there should be a couple of screws. They may have small tabs over them (purely for aesthetics!).
If you lift up the filter cover, remove the filters and remove filter cover (trying carefully not to break it... darn plastic!) there may be some screws above the air outlet.
Remove the fascia cover starting from the bottom. Pull it out over the louvre in the air outlet. It will be clipped at the top near the back. These can be difficult to undo. Once that's done, remove the cover.
For the next bit, make sure that the power is turned off to the unit. (power cord unplugged, isolator turned off or c/b off depending on power source)
Undo the screws on the power box.
Undo the screws on the drain tray and off the left side of the evaporator coil. (Big finned section of pipework). Make sure you support the evaporator coil as it's only connected with copper pipes which bend/kink fairly easily.
You'll need to pull the coil out a little (not too far) and take off the left hand rubber 'bearing' as such from the indoor fan barrell.
On the right hand side of the unit you'll find the fan motor (which is held in by the power box) There should be a grub screw that holds the fan barrell onto the shaft of the motor. This is usually undone with an allan key but have seen them with phillips head screws also. This grub screw might be in a few different places. It might simply be on the right end of the fan barrell or sometimes the righthand column of blades is missing a blade and the grub screw is accessed by putting allan key/screwdriver up missing portion. You only need to loosen the grub screw, not remove it.
Once loosened, the fan barrel can be pulled off the motor shaft and removed.
Once off, you can inspect it for obstructions or broken blades etc. To reassemble is just the reverse of these instructions.
Just a few things to note:
1. Be careful of the evaporator coil not to kink (or break!) the copper pipes or your a/c won't work properly.
2. The drain tray may have water in it if the a/c has been operating recently.
3. Make sure the power is off before pulling off the power box.
This can be a very difficult task and I would recommend having an assistant to help with holding stuff.
Hope this helps!
Jan 17, 2010 | Mitsubishi MSZ09UN Air Conditioner
How to remove centrifugal fan
There should be a Allen key or other type of grub screw which secures the fanblade to the motor shaft. Look between the fanblade vanes close to the motor there should be an opening where you can fit a screw driver.
May 03, 2009 | Heating & Cooling
Lawn tractor engine replacement
some pulley have grub screws on side as well as main bolt on bottom .sometimes heat is needed on pulley to make it expand
Nov 02, 2008 | Garden
Garden Logo
20 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
