Question about Bernina 1008
Bernina service manual for 1008 - nothing on bernina website
Need a service manual - have a user manual but need to go further
  • Bernina Master
  • 10,284 Answers
Consider joining a Yahoo Group for Bernina owners. There are several (BerninaThirtySomethings is great!). The members are very knowledgeable, post manuals in the group files, and will answer most all questions (general and technical).
Service manuals are usually not available to the public, however, I have been able to find them sometimes on eBay, Etsy... The Yahoo Group is probably the best place to look.
Posted on Nov 05, 2015
  • 41 Answers
I am struggling to find a manual online. Will keep looking. In the meantime, if it is urgent, buy one here: Sew4Less Manuals Service Repair
RickE1
  • 202 Answers
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Posted on Feb 07, 2009
SOURCE: i need a bernina sewing machine manual
Sewing Educational Warehouse provided a very similar manual. Thanks for trying
Posted on Mar 23, 2009
Mimito7
  • 128 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Posted on Apr 30, 2009
  • 30 Answers
SOURCE: How do you thread a bernina 1008?
I hope I can explain this in an understandable way!
1. Pull the end of the thread from the spool to the left and "click" it into the little metal guide (on the top of the machine) that is at the back of the long **** in the top. It's easiest to do this by holding the thread tight between your two hands, placing it behind the guide, and pulling forward until it clicks in.
2. for the remaining steps, let the thrread slide between the fingers of your right hand, keeping a little tension on it, as you thread the machine with your left hand.
3. Bring the thread end forward, laying the thread into the ****, and continue downward, along the right side of the vertical silver bar/hook thingy.
4. Bring the thread under that bar from right to left, and go back up towards the top of the wide **** in the front of the machine. As you pull up, the thread will click into the lower bar/hook thingy.
5. Lay the thread along the right side of the wide ****, go over the top of the needle bar (the part that goes up and down in the ****) and bring it down the left side. It will click into the needle bar.
6. Bring the thread back down towards the presser foot. Right in front of the screw that holds the foot on, there is a hook that opens on the left side. Slide the thread behind this hook, and then thread the needle from front to back.
7. Hold onto the end of the thread and run the needle down and back up once. Pull on the thread, and it will pull up a loop of the bobbin thread. Stick the tip of your scissors or seam ripper into the loop and pull the end of the bobbin thread out.
8. Slide your top thread through the slot in the presser foot so it comes out from underneath the foot, and you're ready to go! (Be sure and hold onto both threads for the first few stitches when you start a seam, to keep if from jamming up inside.)
Let me know if you need any clarification.
Posted on Jun 21, 2009
  • 166 Answers
SOURCE: How do you oil a bernina 1008??
Probably the most important is the inside of the hook ring. Remove the bobbin case and open the hook retainer by pressing the catch on the left-hand-side. The hook can then be removed by just gripping the shaft on which the bobbin was mounted and removing the complete hook. NEVER OIL BEFORE CLEANING. This is the single biggest problem I come across - continually oiling any kind of machine without first removing the old, contaminated lubricant will attract grime. So ... get yourself a few cotton buds and carefully clean around the inside of the hook ring (the circular aperture where the hook was), paying particular attention to the small groove running round the outside. Rotate the handwheel to bring the hook driver round halfway to allow the whole hook ring to be cleaned. Use the opportunity to remove any clogged lint and grime that may have built-up on the underside of the stitch table. WHen you're satisfied it's all clean, then run a very light bead of oil around the groove in the hook ring, turn the hand-wheel fully to bringthe hook driver back to the left-hand-side and oil the other side of the hook ring. Before replacing the hook, take a good look at the groove that runs around the back side of the hook near the edge and thoroughly clean that too, before smearing a drop of oil around that edge with a finger. Replace the hook, making sure its properly seated in the hook ring and click the black plastic cover back into place before replacing the bobbin case. Your machine should now sound a great deal quieter, if you haven't done this for a while !! Good Luck !
Posted on Feb 17, 2010
My bobbin case jumps out while I am sewing on my bernina 1008.
it sounds like the bobbin case needs to be replaced, have you cleaned under the needle plate & bobbin area for lint & loose threads
I also would suggest to take the machine to a different sewing machine repair shop.
Mar 05, 2012 | Bernina 1008
I need an instruction book
http://www.berninausa.com/news_detail-n862-r0-i2238-sUS.html
Bernina offers pdf files for out of print manuals.  Use the closest to your model (your 1008 is probably just a newer version of the 1005).  Hope that helps!
Aug 04, 2011 | Bernina 1008
What year was Bernina 1008 in production?
The pdf brochure on their website http://www.bernina.com.au/product_detail-n2-i18-sEN.html
says this is the last mechanical machine in their range and has been offered for decades.
So you might need to do some detective work with the serial number on the machine plate, sometimes you can deduce the year of manufacture from the serial no as they'll incorporate the manufacture year into the number.
May 03, 2011 | Bernina 1008
I need to thread a bernina 2000DE I would like to see a picture
try sewusa.com they have threading diagrams
Nov 27, 2010 | Bernina 1008
Copy ready diagram of Bernina 1008
Not sure which diagram or scematic you want but feel free to contact me at callnrick@yahoo.com and I will reply with your need.
Jul 08, 2010 | Bernina 1008
My 1008 bernina sounds like it is straining to
Your machine needs to be serviced. Take it to an authorized Bernina service person.
Feb 17, 2010 | Bernina 1008
How do I get a free copy of a Bernina 1008 user maual and a repair manual? soft copy or hard copy
You can download the manual in PDF format from www.berninausa.com
Feb 07, 2010 | Bernina 1008
How to set my Bernina 1008 sewing machine up for sewing
That information is in the instruction manual that's available here:
Bernina 1008 Sewing Machine Instruction Manual
Dec 01, 2009 | Bernina 1008
Sewing Machines Logo
203 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
