Question about Makita Drills
Makita hammer drill does not work but green light shows
I was using to drill holes, drilld 16 holes and then it stoppd working ?
    Champion:
  • 304 Answers
Could be a stuck brush. Take the covers of the brushes and check they are long enough and move easily back & forth.
Posted on May 03, 2014
  • 3 Answers
SOURCE: my drill bit doesn't remain secure in the chuck of my drill.
grind bits shank in a triangle to let the drill chuck get a better hold of bit but be carfule because this also takes away the drills ability to slip if it hits something solid.
Posted on Apr 15, 2009
  • 12 Answers
SOURCE: Damaged chuck
Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
Posted on May 14, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
Biggdex35
  • 333 Answers
SOURCE: hilti drill want hammer.
Not positive but I think that it works on air. Is there a cylinder with a piston in it. The orings could be blown?
Im not positive. Just tryn to help
Posted on May 30, 2010
I have a makita hr4011c rotary hammer drill, was working perfect then stopped, plugged into transformer but green light has come on on the drill but no action from the drill,
Did you check to see if the motor is even being energized.? If not check the switch. If yes, then check motor brushes.
Mar 29, 2017 | Makita Drills
My makita SDS rotary hammer drill leaves the bit in the hole while drilling. It is like it doesn't hold the bit anymore. What could be the problem and how do I disassemble the Chuck?
if you are using a normal 3 jaw chuck on the drill , that is normal when hammering
the vibrations loosen of the chuck
a method to stop it is to ensure the chuck is tight and keep pulling the drill out of the hole to remove the grit that jams the bit
Mar 08, 2017 | Makita Drills
Just stoppd working
Tried the brushes?
Mar 31, 2014 | Makita Drills
How to remove wires from the switch from makita hr2450 hammer drill
Use a fine jewellers screwdriver or thin stiff wire in the small holes next to the wire holes.
Dec 07, 2012 | Makita HR2450F Rotary Hammer
Makita dril 18v stopped working
check switch it may have over heated and burned out
Oct 22, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita HR4041C rotary hammer drill
There is no tension to adjust on the Makita HR4041C rotary hammer drill. If you are not getting the hammer action you think you should be it's possible the o-rings on the piston are damaged or not lubricated or the striker is stuck or not lubricated enough to work properly. If you're having problems with the bit turning, there are several gears that turn the bit that could be slipping or are stripped. If you need a manual or brakedown of the tool, one is available on www.makitatools.com. The insides of rotary hammers are fairly complicated so be carefull of what goes where if you decide to take the tool apart to check for internal problems.
Aug 26, 2012 | Makita HR4041C 1-9/16" Spline Hammer
What keyless chucks will work on my makita hammer drill will a dewalt xrp chuck work on a makita
as long as the chuck is used for a hammer drill and the thread size is exact yes it will. I believe the thread is 1/2-20 and also make sure the chuck has a hole in the center for the reversing screw to keep it from loosening up. Let me know if you need more assistance. The thread size is usually stamped on the side of the chuck. Makita sometimes used a metric thread.
Dec 31, 2011 | Makita Drills
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
Drills Logo
103 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
