Question about Porcher Home
Leak remove flap valve
Re. Duravit Happy D toilet (tank No. 0929100005)
Remove and clean the flush valve and the flush valve seat(it is the flap that opens up to allow water to flush the toilet). Once the edges of the valve and the seat are cleaned, possibly with "0000" grit bulldog steel wool, it should not leak anymore. To make sure it is not leaking, once tank has refilled completely, put some food die in the tank. If, after 10-15 minutes, the water in the toilet bowl is colored, you have a leak from the flush valve. Replacing the flush valve is very easy - just bring the old one with you to the hardware/plumbing store and ask for a replacement. Blessings and good luck!!
Sep 23, 2017 | Duravit Home
My 2001 nissan maxima problem with the idea,goes up an down
You must mean problem with the idle, it goes up and down.
The first thing to check is the coolant level, make sure it is full. the next thing is to check for any vacuum leaks or lines that are off or broken, the last thing is the idle air control valve, try to remove it and clean valve and port, also clean the throttle body, you will need to clean where the flap plate is, clean the plate and body around it.
Nov 28, 2012 | Cars & Trucks
I have a 4 year old offshore 4 wheeler 110cc it has always run perfect. Recently it has developed a prob that it did not want to run unless the choke was on full closed position. I thought the carb maybe a...
So, when you remove the float bowl, is there actualy enough fuel in it, and the fuel flows freely from the fuel tap, into the carburettor, main jet is clear from obstructions, also primary air jet, no air leak between carb and cylinder head, does the choke flap have a spring mounted upper section if so is it still in place, by this i mean does the flap completely close the apeture when on, on this type of flap eventually the spring breaks off and gets traped in the inlet valve not allowing it to fully close, if it is the choke type is solid construction, then this would not be an issue, it would however be good advice to check the compresion, to rule out a problem with valve leakage which on a small engine would be detrimental, when you say force feed the fuel, do you mean you put the fuel down the inlet?
Apr 29, 2011 | Honda XR 100 Motard Motorcycles
Model #ed22tqxvw00 problem: my water faucet in door was leaking when not being used so I turned off the water supply to the refridgerator but the faucet continues to leak drops of water. Where is the...
A couple things you need to check for your refrigerator water leak. First, if the water is actually leaking from the plastic tube for the water dispenser, and not from the flapping door that opens to allow ice to flow through door. If water is dripping from the flapping door, this could be ice melting, are you having any freezer temperature problems, is ice cream or bread soft ? If temperatures are fine, inspect the ice in the bucket, is it in clumps or one solid block of ice? If you have either this problem or the water is dripping from the plastic tube for the water dispenser, you likely have a problem with your water valve for either the ice maker or the water dispenser. Either way, both valves are part of one assembly, and both have to be replaced.
The other thing you need to check is that source water valve you shut off. Since there is no pump in a refrigerator, only those valves, the water that is leaking out of the fridge has to still be coming into the refrigerator. In other words, either that source valve is not shut off completely or it too is bad, or you shut the wrong source valve off, possibly for your house humidifier.
Nov 04, 2010 | Whirlpool ED5FHEXMQ Side by Side...
I flush the toilet, tank fills up and cuts off, but the water leaks out, then the tank cuts back on to fill up and this is a vicious cycle.
Go to the hardware store and get a new flush valve flap made by Korky and install it. Your flush valve flap has worn out and allowing water to leak through.
Oct 12, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Kohler Rialto flap valve leak
if so cut 1/4 inch off the bottom of round part of flat valve
Feb 23, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Dishwasher not washing dishes properly
Thanks akubra_lands, it worked for me too on model DW28W. I thought I should elaborate on your answer for anyone else who comes across this while researching the same problem.
The repair is ridiculously simple (takes about 10min) and the only tools needed are 1 philips/posidrive screwdriver and 1 flat blade screwdriver. Assuming you've unplugged it from mains power:
  1. Tip the dishwasher on its right hand side (looking from the front).
  2. Remove 4 screws from the metal base - 2 front and 2 rear (the rear ones have anti-rattle washers on them).
  3. Pull the base away, taking care of the pair of wires leading to the flood indicator float switch which is still attached to the base.
  4. Remove all 4 screws which fasten the solenoid valve to the pipe which leads from the pump upwards to the center of the tank (which feeds the lower spray arm).
  5. Pull the solenoid/valve body off the pipe and you will see it has a whitish plastic flap with a hinge at the top end.
  6. Use the flat blade screwdriver to gently prize open one side of the flap hinge and twist the flap until it is completely free of the valve body. Put the flap to one side.
  7. Replace the valve body, without the flap, and secure all 4 screws.
  8. Reassemble the dishwasher. Done
Now take a moment to admire the handiwork of the engineer who planned the failure of that innocent little plastic flap around 6 months after the expiry of the warranty.
I actually had a repair man come and look at the problem, and yep, right on cue, he told me it needed a new pump motor. $300. When he realised I was on to him he just gave up. So hard for repair people to do an honest day's work these days..
Nov 24, 2008 | Dishwashers
Leak on freezer side door from control panel samsung RS2534
the trim unclips, to remove gently prise off using a small knife, you may find the you have either a faulty water inlet valve or the ice flap is not closing correctly. Regards Advisor
Jul 27, 2007 | Samsung RS2534 Side by Side Refrigerator
Home Logo
Top Porcher Home Experts
bobalix
ray gallant
Stan Ford
Are you a Porcher Home Expert? Answer questions, earn points and help others
