Question about iFixit MacBook Pro 13" Unibody Model A1278 Mid 2012 Hard Drive Cable
Vertical lines on laptop screen
Laptop shows vertical lines on screen. requires restart
  • iFixit Master
  • 3,320 Answers
How is this a hard drive issue?
Posted on Apr 02, 2014
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
Display Problem - with vertical regulaqr line
I would connect your laptop to an external monitor first of all.
That will rule out laptop Motherboard problems. If it shows a good picture on an external display, a new screen will be required.
Spares can be found at ebay.com
Hope that helps.
Nov 29, 2010 | Toshiba Satellite P105-S6104 Notebook
There is a green vertical line on my display when i opened it today
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please turn off the laptop...take the battery out as well as unplug the adapter cord.
once done, keep the power button of the laptop pressed for around 10 seconds.
insert the battery back in and plug the adapter cord.
turn on the notebook and check.
in case issue persists, please restart the computer..tap the f2 key on the lenovo logo. please check if the vertical line is visible in the system setup bios screen as well. If yes, then the LCD requires a replacement
If not then please reinstall the video drivers.
Nov 24, 2010 | Lenovo ThinkPad T61 Notebook
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
Vertical lines on lcd how can i fix it works perfect with ext monitor and i did bios update and it help some?
Restart the Computer and access the BIOS and check if the vertical lines are visible. If the vertical lines are visible in the BIOS then the issue is with the LCD screen itself and may require service. This is confirmed when an external monitor works fine. If the issue is related to the video card of the Computer then the lines should also appear on the external monitor which is not the case.
Oct 24, 2009 | Dell Latitude C600 Lcd LCD Display
White vertical line on monitor screen
The vertical line is because the screen is going, it needs to be replaced fix the problem. Try searching on Ebay if your laptop isn't under warranty.
Aug 30, 2009 | HP Pavilion zd8000 Notebook
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
2 vertical line in laptop screen coming
Only way you are going to be able to remove this is by replacing the LCD. It is not a huge job, and not extremely expensive if you can do it yourself.
Here is a link to the maint and service guide that should show you removal and replacement of parts.
http://h10032.www1.hp.com/ctg/Manual/c00637377.pdf
Mar 17, 2009 | Compaq Presario M2000 Notebook
My screen showing a vertical line
Replace the laptop under warranty. No point trying to fix the error and voiding the warranty.
May 25, 2008 | Compaq Presario Notebook
iFixit MacBook Pro 13" Unibody Model A1278 Mid 2012 Hard Drive Cable Logo
79 people viewed this question
Top iFixit Computers & Internet Experts
David Payne
David Payne
Are you an iFixit Computer and Internet Expert? Answer questions, earn points and help others
