Question about Leisure Cookmaster CM101NR
Spindle on oven knob broken
How do I get inside to replace this?
Gaggia classic steam knob
Have you turned the steam valve off tightly and cracked the knob inside allowing it to turn on the brass spindle.Try pulling the knob off and turning the spindle with a pair of pliers or a small adjustable spanner.If the spindle keeps turning you may have sheared the spindle off inside.If this is the case you will need a new steam valve complete as they are not repairable.Steam valve cost about 35
Tools required 5 mm alan key and 17 mm spanner for steam pipe
Jun 16, 2012 | Gaggia Classic Espresso Machine
Both oven knobs have come off and although don't appear to be broken we can't seem to fix them back on properly
First try a layer of silver paper around spindle.
If not satisfactory then try a "No nails" type of clue.
Jun 04, 2012 | New World E90DOa Electric Double Oven
The spindle connecting the volume control knob to the control itself has broken. Does the whole assembly need to be replaced? I don't have the old spindle.
Do you mean the spindle on the back of the round knob? If this is the case then you simply need a new knob from the manufacures as the bit that fits over the pin coming out of the machine is a one peice moulded item. If you are very nice to customer services at Kenwood, they may send you one for free. Next time be a wee bit more careful not to knock the control knob as it is quite delicate.
IF on the other hand it is the volume spindle couming out of the unit, then yes this is a whole item replacement. This will need to be repaired by either a accredited Kenwood repair agent or a competent repair shop depending on whether this item is still under gaurantee or not.
Mar 15, 2011 | Kenwood KRF-V4060D Receiver
Is the knob that turn the light on repairable? The oven light is on but would not turn off. The knob just keeps turning...
HI,and a merry Xmas.
Yes it is repairable, it is going to be one of two things.
1--the control knob is cracked or broken causing it to twist round without turning the control.
2--the spindle on the control is broken or loose inside the switch.
Pull the knob off, and see if yopu can turn the switch on and off with a pair of grips or pliers.
This way it will enable you tell if it is just the knob or the switch that is faulty.
Good luck.
Please leave feedback for my suggested solution.
Dec 25, 2009 | DeLonghi Ovens
The grill / top oven knob will not operate the grill any suggestions?
It is possible the knob is slipping round and not turning the spindle of the switch, or the spindle is broken inside the switch, or the switch is partially seized up.
Pull the kjnob off the switch, and try turning it on wioth pair of pliers or grips, if that works, then the switch is probably o/k.
Also spray some WD40 onto the switch spindle, and inside the switch.
Please leave feedback.
Thanks.
Nov 13, 2009 | Ovens
My timer knob is broken. How can I order only that part?
I would advise you to call Kitchenaid Customer Service. They would be able to send you a replacement timer knob at no cost. You may simply pull off the broken timer knob, and the new knob will snap in with ease.
Their toll free telephone number is 1800-541-6390.
Jun 16, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
The knob is broken
youve probably solved the problem by now but i would use a spanner or molegrips on the spindle to turn it, fitting a new one would have fitting instructions included.
Sep 28, 2008 | Amerock 3 Ring Knobs - BP1586
REPLACING CONTROL KNOB AND SPINDLE ON TUMBLE DRYER
Yes you should be able to get a new knob from your local repair shop, take it along with the model number, they just push on.
Nov 30, 2007 | Dryers
Leisure Cookmaster CM101NR Logo
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
