Question about Garmin Ga-nhwc2: Nuvi 2460 2495 2555 2595 3790 Lm W Gps Usb Hardwire Power Cable
White Lines on screen
Lines across screen
Akai 13" TV/DVD Combo CTD-1390 White Lines going across the screen with enlarged images on screen.
Retrace lines. This fault is called so. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to CRT screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 28, 2014 | Akai Televison & Video
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Vertical white lines across screen
whatever brand your tv is go there .com maunals it should show u what u need to know
Jul 14, 2008 | InFocus ScreenPlay 61" Rear Projection...
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
Garmin Ga-nhwc2: Nuvi 2460 2495 2555 2595 3790 Lm W Gps Usb Hardwire Power Cable Logo
26 people viewed this question
Top Garmin Sport & Outdoor - Others Experts
Are you a Garmin Sport and Outdoor - Other Expert? Answer questions, earn points and help others
