Question about Dometic Rooftop RV Air Conditioner
Dometic air conditioner not blowing cold air.
My dometic air conditioner in our horse trailer/living quarters is blowing just air not getting cold does it need to be charged is that possible? Thanks
    Top Expert:
  • Dometic Master
  • 8,673 Answers
Make sure fan on auto if ok and unit on cool check compressor coming on if ok bad cooling unit
Posted on Oct 06, 2017
4 Suggested Answers
SOURCE: Dometic air conditioner
1The air coditioner does run on Electric. 110V 2. No you do not have to unhook the battery 3. Yes you need to put water in the hot water heater so you do not burn the unit up.
Posted on Feb 18, 2009
  • 34 Answers
SOURCE: Dometic Air conditioner model 57915-531 blows hot air
Have freon and compressor checked out, could also be bad capacitor
Posted on Aug 11, 2009
  • 413 Answers
SOURCE: Our Dometic Duo Therm Air Conditioner leaks inside
Hi, hopefully it is just your drain stopped up. If you can climb up on the top of the trailer, on your air cond. unit will be a drain. It will be about 1" around and will be located close to the bottom of the unit. It may have a hose connected to it or it may just drain on the roof. When you find this, see if it is plugged up with dirt, etc. You can stick something up in it to unclog it, but be aware not to jab the coil tubing with what ever you are using. You may be able to use a shop vac or compressed air also.
If it is not stopped up, depending on the age of the unit, the condensate pan, (which hold the water) may be rusted through. You will have to take the top of the unit off and a couple of covers to get to the front coil (looks like a radiator). The pan is underneath the coil.
Hope this helps and I hope it is the easier of the two. Mark
Posted on Aug 06, 2011
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
My ac doesn't blow cold
Can you hear the compressor starting? If so, suspect broken pipework and loss of refrigerant. If not, suspect loose wire to compressor or thermostat
Apr 19, 2012 | Dometic Rooftop RV Air Conditioner
Are trailer is only a couple of years old and we have only used it a few times - twice when we have used it we left the air conditioning running and left the trailer for a few hours and come back and it is...
Here is what happening . This has nothing to do with you having it on while you stepped out for a few hours. The unit needs to be cleaned/ filters/screens/fins/coils. This problem would of happened even if you were in the trailer as it was running. The issue is after a while, sense it needs to be cleaned it loads up and then starts to freeze and then once it starts to freeze coils etc... it then starts only blowing warm air. When you turned it off, and let it set for a while, reason it started working again, is because the ice that built up defrosted some to have unit operate proper again. Solution is to clean the unit good. Thanks Mike from fixya.
Jul 31, 2011 | Dometic Rooftop RV Air Conditioner
I have recently replaced the fan motor on my Briskair roof top A/C unit, should the squirrel cage draw air from inside the trailer and blow out rear of the unit, or have I installed this fan incorrectly?
Yes the air should be drawn from the trailer, over the cold coils and then
back into the trailer, whether rear or front.
The condenser coils should be self contained on top and blow
warm air outside the trailer
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 26, 2010 | Dometic Rooftop RV Air Conditioner
The fan runs, but doesn't get cold. It is a new Dometic, but has been sitting for 4 yrs. It is on a Gulf Stream (Cavalier) travel trailer.
You'll have to get someone familiar with system to check relays, capacitors, as well as power to compressor. Can be dangerous, so please if not 100% sure what your doing, ask someone who does know.
May 24, 2010 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,275 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
