Question about Cycling
BMX bike rear braking system
Once applied the rear brakes don't release easily. I Is there a manual that will help me fix this problem
  • 51 Answers
GREASE AND BRAKES DONT MIX!!! If they are whats known as "990" mounted brakes you need to first remove the back wheel, squeeze the brakes together and remove the "straddle" cable. Then their will be 2 bolts on the top of where the brake arms are mounted. you will need a hex head wrench to hold and tighten these (usually 5mm or 7/32). Then an adjustable wrench for the tension nuts. slightly loosen the hex bolts and turn the tension nuts towards the front of the bike. (left nut : spin to the right... right nut: spin to the left) then hold and tighten the bolts back down. reassemble. if this did not work you may need to remove the brake arms and clean the mounts with a brilo pad. be sure to keep the springs on the correct side. if it is a conventional brake setup (1 bolt and spring). a good way to fix them is to remove the sping and bend the ends outwards a little bit. and remember. with any brake setup it is wise to use a Linear brake cable. I suggest Oddysey or Animal Brand cable. =) good luck
Posted on Jul 12, 2009
    Problem Solver:
  • 7 Answers
Put WD40 or soome greese on it.
Posted on Jun 16, 2009
Does the Eastern 2010 Night Prowler have front brakes?
I am unfamiliar with this bike but most do have front and rear brakes . You should be able to see brake calipers mounted on forks and they are operated by hand lever on right side of handlebars.
Aug 25, 2011 | Eastern Bikes 2010 Night Prowler BMX Bike
Adjusting brakes on relaigh bmx
Vist the Raleigh (note the spelling) website amd download the Single Speed Manual. Page 13.
http://www.raleighusa.com/downloads/owners-manuals/
You could also use any Search Engine and enter "adjusting brakes on bmx bike" for video instructions.
Jul 07, 2011 | Mountain 3 Raleigh Bikes Bmx Road Frame...
The rear disc brakes (both right and left) are equally tight causing a burning brake smell and heating up the discs. We replaced the rear pads and lubricated the slides to no avail. Is there some kind of...
do a test drive with the main ABS fuse out of the engine fuse box and drive the car to see if this is the problem. It is ok to take the ABS fuse out of engine because it does not affect you from not stopping. You need to read link: http://en.wikipedia.org/wiki/Anti-lock_braking_system
May 27, 2011 | Jeep Cherokee Cars & Trucks
I have a 99 R1100RT and the ABS lights keep flashing or once in awhile just stay on and don't flash. It's my understanding they should go out when working right. I have replaced one prox and check the rear...
ABS - Anti-Lock Braking System And EBD -Electronic Brake-force Distribution In Plain English Posted by: Rohit Khurana March 1, 2010 in Automobile Technology
AdvertisementCarBlogIndia Technology Articles , today I will talk of one of the most talked about safety feature called the ABS And EBD. Again I will try to keep the language simple and human understandable (which non-engineers can also make some sense of), pun intended.
What Is ABS ? Anti-Lock braking System system or ABS is a safety system which prevents the wheels on a moving vehicle from locking up(or cease while rotating) while braking. ABS offers improved vehicle control over dry and especially slippery surfaces by reducing the braking distance but it can also increase the braking distance in case of loose surfaces like snow, gravel etc. Ever since the invention of ABS, it has been evolving and the recent systems not only prevent wheel locking but also electronically control the front-to-rear brake bias, which we know as Electronic brake force system, Traction control system, Emergency brake assist or Electronic stability control.
Working Of ABS
Advertisement
When brakes are applied under heavy loads, the braking pressure becomes high resulting in heavy braking or in other words locking up of wheels. The ABS overcomes this by monitoring the wheel speed and releases pressure on each wheel brake lines in the form of rapid pulses switching between different brake lines. which prevent locking-up.
Preventing lock-up under heavy braking helps the driver in maintaining control over the vehicle. In modern ABS an individual brake line is provided for each of the four wheel enabling different braking pressures for different road surfaces of the wheels.
What Is EBD ? Electronic brake- force distribution system also called as Electronic brake-force limitation is an automobile brake technology that automatically varies the amount of force applied to each of a vehicle's brakes, based on road conditions, speed, loading, etc.
EBD system is always coupled with anti-lock brake-force system. The most important function of EBD is to maintain vehicular control with variation in braking pressure applied to each wheel in order to maximize stopping power. Generally most of the weight of all vehicles is carried by the front end so the EBD ensures less braking pressure at the rear end to avoid skidding. But in some EBD's the distribution of braking pressure at the rear end is more initially when the brakes are applied before the effects of weight transfer comes into play.
Working of EBD system An EBD is a subsystem of the abs and its function is to control the effective adhesion utilization by the rear wheels. this definition has been given by SAE in its technical paper no. #920646.
Advertisement
The Antilock brake force system releases pressure in different brake lines at the time of heavy braking to prevent locking-up. The action comes in the form of releasing pressure from the braking circuit when it detects extreme and rapid deceleration in any of the four wheels in order to make sure that the driver maintains control over the steering during panic or emergency braking. For example if the wheels of a vehicle are on snow as well as asphalt then in case of emergency braking the ABS will monitor the speeds and eventually the EBD system will release less pressure for wheels on snow and more pressure for wheels on asphalt to prevent wheel lock-up
Oct 07, 2010 | 1998 BMW R 1100 RT (ABS)
When I take my daughters front wheel off her Diamondback bike I need to reajust the front break. How can this be avoided?
By always placing the wheel firmly into the fork's dropouts and then then tightening the quick release. Adjust the brake centering and it should always stay the same UNLESS the brake centering itself is moving every time you disconnect the brake to remove the wheel. Then it gets complicated.
Look here:
http://parktool.com/repair/byregion.asp?catid=14
Aug 02, 2010 | ProMax 197NC Bmx V Type Brake Set, Rear,...
I have a ironhorse bmx bike and i cant figure out how the rear brake goes together. how can i fix my bike?
There are few variations on these brakes but this Youtube clip will give you the idea. http://www.youtube.com/watch?v=waX3p7oFTmM
Jun 09, 2010 | Iron Horse LZ1 20 Boys' BMX Bicycle
ABS light will not reset on BMW R1100 rt after replacing abs sensor
you have to check the wires going to the abs, could be a bad wire, if they are ok then either the new sensor is malfunctioning, or the abs sentral is fried
Jan 17, 2010 | 1998 BMW R 1100 RT (ABS)
I have an ironhorse freestyle bmx bike and I am having some issues with the rear brake. The rear brake was detached so the bike would perform more freestyle tricks and i cannot get it reattached so that...
Here is a great site with more than just brake info:http://www.bikeguide.org/how-to/brakes/brakes.php Please let me know if this helps.
Dec 03, 2009 | Cycling
New mongoose 20'' bmx. trying to adjust the brakes???
undew the screew at the back of the breakes and turn them round slightly so the wheel in midlde then tighten back up should stay in midle then just not put on straight thats all mate
Jun 18, 2009 | Mongoose Menace Street Dirt BMX Bicycle
Cycling Logo
180 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
