Question about Refrigerators
Deep freezer gets cold and then it starts defrosting and then freezes again what could be causing this issue it is only a year old. GE model FCM7SUBWW
7 cu
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
Sounds like the thermostat ids giong bad
Posted on Apr 13, 2014
  • 183 Answers
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Posted on Aug 23, 2007
Amigaman
  • 248 Answers
SOURCE: freezer is cold but not freezing
Look for frost on back wall of freezer on bottom half. If present it's not defrosting. Number 1 culprit is a defrost heater gone bad. You will have to remove lower cover in rear of freezer section to expose coils. Unplug unit pror to doing this. The defrost heater is at bottom of these coils. It has wires to both sides of it. You will need to check continuity of heater or remove heater and take to appliance store and have them check it. If it's open replace it. Use a hair dryer to remove frost from coils to restore airflow. If heater is ok, problem could be a bad thermistor or a bad board. Let me know how you make out with heater.
Posted on Oct 06, 2007
Bgillespie
  • 89 Answers
SOURCE: GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Posted on Dec 17, 2007
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
blueextc3221
  • 15935 Answers
SOURCE: GE TFX20SA back wall of freezer freezing (snow
CLICK HERE for an expanded view of your freezer section.
Can you see the evaporator fan moving when it is plugged in?
Otherwise your defrost timer has failed.
#257 in THIS diagram
CLICK HERE to see the part.
CLICK HERE for testimonials about installing the defrost timer yourself.
Thanks for using FixYa - a VERY HELPFUL rating is appreciated for answering your FREE question.
Posted on Jul 13, 2009
Deep chest freezer 7cu will get cold and freeze items, then it stops freezing and defrosts the food. Not sure what could be causing this problem it is just over a year old. Anybody know if this might be...
It appears that the thermostat is not working properly and is taking much too long to turn back on after it disconnects power to the compressor. There is no relay in that unit but maybe a start capacitor on motor that might be checked out also.
Apr 02, 2014 | Freezers
Kenmore freezer gets cold and freezes but then completely dethaws itself
usually when aq defrost timer goes bad it gets stuck in defrost. I would suggest replacing this first
Mar 29, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE SIDE BY SIDE MODEL #GSH22JFRE CC FREEZER COIL FREEZING AND REFRIG NOT COOLING. DEFROST MANUALLY AND REFRIG COOLS FOR A COUPLE DAYS, THEN FREEZER COILS FREEZE AGAIN
We have a GE side by side that was only 4 years old before it starting giving us problems-coiling freezing over. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Nov 23, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Freezer not freezing and blowing luke cold air. Fan running full time.
rotate the defrost heater timer until it clicks and see if the defrost heater is working
Jun 02, 2009 | Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
your defrost timer is bad. this device is dual purpose, it is a small heater/solenoid that calls for the compressor to turn off so the lines can defrost (usually does it once every 48 hours or so). it looks like a round button clipped to the coil lines in the freezer behind the plastic paneling where the cold air comes out. you need to replace that part, which is actually very inexpensive compared to a new fridge. it will unclip from the coil line and the two or three wires will either disconnect or you may have to cut them and splice on the new ones from the new defrost timer. either way it is a job that will take anyone with basic hand tools less than an hour to do.
May 29, 2009 | GE GSH22SGRSS Side by Side Refrigerator
GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
Jan 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GSS20DBMB GE side by side refrigerator
If the fan is running you more than likely have a defrost problem.
look at the back wall of the freezer section if it is frosted up. it's not defrosting.
There three components in this system. The defrost heater, the defrost termination stat., and the defrost timer. Newer refrigerators do not have a timer per say it is build into a electronic board usually mounted on the back of the refrigerator under a metal plate. The termination stat is the cheapest part @ $ 25.00. The heater should run @ 50.00 to 70.00. The board could be as much as 200.00 or more. If the refrigerator is over 10 years old you may wish to look into getting a replacement. Appliances are designed to start failing after 10 years old.
My opinion.
If you unplug the refrigerator let it defrost then plug it back in. it will work properly about 3 days before it frosts back up.
hope this helped. Good luck
May 20, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Defrost issues
If it's around 2-3 years old, my first guess would be the heater is bad. The GSS models have problems with the heater almost always about that time.
Test the heater and the defrost thermostat for continuity with a multimeter. Whichever one doesn't get continuity is bad and should be replaced. If they are both good and the evaporator fan is running like it should, it will be the main control board located on the back of the unit.
Click here to see the defrost heater
Click here to see the defrost thermostat
Click here to see the main control board
Let me know if you have any other questions about this issue.
Mar 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
