Question about Toshiba W403 VHS VCR
How can i contact mitsubishu directly re problems with my hs-u748 setting new time
Can;t change time
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Toshiba Master
  • 102,366 Answers
Honda HS 55 snow blower service manual
Contact Honda directly and request the HS 55 service manual.
Jan 13, 2018 | Honda Garden
Need wiring diagram for ctm hs-588 mobility scooter
Here is the manual. I am still looking for the schematic. the manual does have a god troubleshooting section. http://scooterland.net.au/wp-content/uploads/2015/08/User-Manual-HS-589.pdf
Oct 29, 2017 | Ctm Health & Beauty
Diagnostic red light flashing 9 times on CTM HS 360
hi Leslie, Sadly that is most likely a controller fault...
Please contact me if in the uk as i offer a free testing service...
Regards
Rob
May 02, 2016 | Ctm Health & Beauty
Canon SX40 HS wont reset to factory settings
I own a same model camera but the problem you mention is new to me. I would try re-setting individual menus to their defaults first, then switch off the camera for sometime then re-start. This time, try the factory re-set option. This is no definite solution to your problem, but it;s worth trying because I had a smaller (pocket-size) Canon camera sometime back that worked that way.
Aug 18, 2012 | Canon PowerShot SX40 HS Black 12.1 MP 24mm...
Will the Plantronics HS 34 work with my Blackberry Torch (with an adapter)?
Your Blackberry Torch has a 3.5mm jack which can be brought down to 2.5mm with an adapter but it also requires three rings on the pin (four contacts) whereas the Plantronics HS34 only has two rings (three contacts).
Good luck from Headsets Direct!
Sep 12, 2011 | Plantronics HS-34 Consumer Headset
Ctm hs 2800 turn on key light come on and blink 7 time then go out push joystick foward motors kicks in and out and lights blink 7 times and then frist red light keeps flashing
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul****this will be your problem***
8. Power Module Faul
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Oct 31, 2010 | Ctm HS-2800 Power Wheelchair
MY MITSUBISHU WS 55511 WHEN POWER TURNED ON WILL
I have the same set doing the same thing. I will replace IC and fuses to see if that will fix it.
Jan 05, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Replace our VCR
I see someone selling that exact model on Ebay. Or there are many other Mitsubisha S-VHS similar in Model. I would stick with what you (they) are familiar with.
Hope that helps...
Geno
Apr 04, 2008 | Mitsubishi HS-U748 S-VHS VCR
Setting date and time on a Mitsubishi VCR
My Solution for Mitsubishi HS-U500 VCR setting the date for 2008 and beyond:
I had same problem with this old unit as everyone else has.  Since the year really doesn't matter (except maybe when you're setting to tape near a new year), here's how to get the day and dates correct:
On the remote, push Menu button, then select "First time setup", then select "Set the Clock", then select the month.  Now, start adjusting the YEAR and watch how the "days" change with the years.  Adjust the years so that the "Day" (Monday, Tuesday, etc.) matches the date (1,2, 22, 23, 28, etc.) in the month.  Then cycle thru the rest of the items and get out by hitting menu button again.
That's it!  That's my quicky solution.  Caveat: This may not be permanent with leap years and the like, so you may need to check it from time to time to make sure the days match up with the dates.  But you can do this when you go to set up for timed taping.  Hope that "FIXes" it for "Ya"!
Jan 22, 2008 | Mitsubishi HS-U595 VHS VCR
Toshiba W403 VHS VCR Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
