Question about N'FINITY Dual Zone Stainless Steel Door Right Hinge Wine Cellar Capacity: 187 Bottles"
E5 trouble code on n'finity wine cellar?
What is it? Cellar is cycling on and off every few seconds.
N'finity wine cooler
call the repair man if probably needs recharged with freon
Feb 16, 2015 | allavino MWR-1682-BL-C 170 Bottle...
Where can I find corner wine racks?
For a corner to build of terracotta stones . 6 bottles in one stone
free stackable
May 29, 2012 | Furniture
My kool space wine cellar is not holding temperature
has the cellar ever worked right in your home? These small refrigeration units basically move heat from a conditioned space to another space that is not objectionable such as your home where your central air system then moves the btu's. This being said, the cellar has a ventilation system that must pull in room air and push out the box air. these vents must be clean and clear of obstrucions to ensure proper performance by the equipment
Nov 26, 2009 | Vintage Keeper Koolspace Wine Cellar
Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
Eurocave Repair
can you tell if if it's running by putting your hand on the compressor,then we can go from there
Dec 17, 2008 | EuroCave Comfort 260 Collector's Package...
Cuisinart Private Reserve wine cellar
It is normal. The goofy thing about this wine cellar is that once the ambient temperature is above 70 degrees - which is actually a low room temperature - the fan works constantly. You would have to make sure the wine cellar is in an area that stays below 68 degrees (brrrr) for it to shut off sometimes.
-Tha Mp3 Doctor
Sep 13, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
N'FINITY Dual Zone Stainless Steel Door Right Hinge Wine Cellar Capacity: 187 Bottles" Logo
329 people viewed this question
Top N'FINITY Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a N'FINITY Furniture Expert? Answer questions, earn points and help others
