Question about Tascam US-144 Sound Card
I recently bought a mic that requires 48v Phantom power. I am afraid to buy the Tascam us144 because it is vague on the Phantom voltage. In fact, it doesn't give a voltage at all. I would like to buy this unit but not until I know it will work with my mic. Any info on this for me? Thanks,
  • 327 Answers
This set-up is very compatible and you should have no trouble at all.
Posted on Oct 31, 2007
0 characters
3 Points
I have followed the directions (the manuel and even youtube videos) about 5 times already, but I am not getting any reading from my mic. I have the US-144 and a mac. I talk into the mic, but it's not...
What model is your mic? Some mic's need the phantom power switch turned on. I have the US-144u and it works great with my RODE NT1-A both on MAC and PC. What software are you using to record with?
If you mic is not using the XLR type connection, you will have to set the switch to Guitar / Line In not Mic
Aug 10, 2011 | Tascam US-144 Sound Card
I've tried several mics: mxl 990, Sure sm58/57, an AKG mic, and I get very low input signal or no signal at all from the mxl 990. The problem is the same regardless of phantom power. Cranking the input...
1. maybe the impedance of you mic did not match to your sound card..
2. sound card did not support you dynamic mic...try to use FET or condenser mic..
May 24, 2010 | Tascam US-1641 Sound Card
Tascam us144 clipping
1. make sure your incoming signal is not too strong, this is i think the most common reason for clipping.
2. check the settings under audio performance in tascam control panel.. for vista click start> all programs > tascam> control panel> try changing the latency to normal or whatever works best with your system.
I never seem to have this problem anymore since I upgraded my desktop, with my slower system I had this problem all the time, so badly it was impossible to record an entire track.
Jan 27, 2010 | Tascam US-144 Sound Card
Getting mic setup thru cubase le 4
Make sure phantom power is enabled on the Tascam audio interface and you must enable the input in cubase that corresponds with the interface input on the track you are trying to record to.
Sep 28, 2009 | Tascam US-144 Sound Card
Recording on cubase
Remember when recording in 24-bits, you have 8 bits EXTRA over 16-bit recording, per voltage sample.  This means that for each voltage step that would be recorded in a 16-bit recording, a 24-bit recording will take 256 steps!  In other words, the fidelity is MUCH greater, so even if your levels seem low, that can be OK, since you have around 100 dB of headroom to play with, and can increase the signal many times with acceptable fidelity.  What you DON'T want to do in digital recording is CLIP, which is a virtually unrecoverable fault in the recording.
Jul 25, 2008 | Tascam US-144 Sound Card
Tascam us 144
Stereo requires two different inputs, as the very name implies. If you're using just one mic, it is possible to "pan" that input to both left and right, but is not truly stereo. For true stereo, you must have at least 2 mics, or 2 or more of any other sources...accordianman
Feb 22, 2008 | Tascam US-144 Sound Card
Only on one side
cheal faders balence on the mixer ect is that unit phantom powered ready also
Jan 27, 2008 | Tascam US-144 Sound Card
Phantom power
are you using the xlr connection socket. There should be 48 volts dc bwtween pins 2 aqnd 3 on your xlr connection. check for this and that the mic cable you are using is decent quality and has 3 internal conductors - some cheapies dont. the unit the require some repairs If there is no voltage on its input sockets.
Dec 09, 2007 | Tascam US-144 Sound Card
Tascam US-122, blown pre-amp?
After a while on the net I could not find anything specific to this issue but I do have a link to the manual. which some tech specs and drawings hope this helps. copy and paste the text below into your internet browser
Jul 31, 2007 | Tascam US-122 Sound Card
Tascam US-144 Sound Card Logo
476 people viewed this question
Top Tascam Audio Cards Experts
Brian Sullivan
Brian Sullivan
Ben Armstrong
Are you a Tascam Audio Card Expert? Answer questions, earn points and help others
