Question about Nordic Track NordicTrack T6.3 Treadmill
Console lights come on but no buttos work
Insert key and lights come on...you can incline from 4 on up...but nothing else will work
Display is in 'demo mode'?
Before inserting key hold down stop key then insert key then turn off demo mode
Jun 03, 2015 | HEALTHRIDER S500XI TREADMILL Console
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
I just bought a Nordic Track X9i incline trainer. Started working well, however after a few hours of use I cannot use any control keys and belt and incline does not work. The touch screen display works but...
You should immediately replace the console. That console will just keep getting worse. This is endemic of this brand, however it usually happens a lot further in the life of the unit. When you call Nordictrack have your model number.
Aug 11, 2013 | Nordic Track Incline Trainer X9i...
My treadmill won't start. It sounds like it is inclining when I insert the key but nothing lights and it is not moving.
Dear Sir:
Inside test the fuse and replace use DVOM, or reset the c.breaker
2) Adjust the reed switch see the diagram attached, clean,and tight the connector very well. Tigh the ribbon cable from keypad + connector from display board vs lower board
3) Lube the deck vs deck belt, this produce enough friction.
4) test the input motor voltage,if there are the motor need repair or replace
5) Test the output voltage from the m.motor board for the input motor voltage, if there are NOT the board is faulty.
6) Try after your fix, the software calibration for diagnose, and troubleshooting.
sincerely. God bless you
May 01, 2012 | Proform CrossTrainer Treadmill
I need to know where the batteries go
Dear Sir: I will help you, please do the following step: Instructions Things You'll Need
  • Power supply
  • Standard screwdriver
  • Batteries
  • Access to local fuse or circuit breakers, if necessary
    • 1 Check to see if the Pro-Form device is properly plugged into a working, grounded power supply if none of the console buttons are working. Turn the device on and reset local fuses or circuit breakers if necessary; reset the circuit breaker switch on the base of the unit.
    • 2 Turn off the fitness device and unplug from the power supply if the console only shows zeros or the console buttons are not working. Use a standard screwdriver to open the battery compartment on the underside of the console. Pull out the old batteries and recycle, if possible. Replace with new batteries, using the old batteries as a guide for the size and type of batteries needed. Place the flat end of each battery against the spring inside the battery compartment and gently push the battery into place. Close the battery compartment and restore power.
    • 3 Press and hold the "Stop" button if the console is only flashing repeatedly, indicating that the device is in demo mode. Insert the console key and push the "Speed Down" button to turn off the demo mode on the unit. Remove the console key.
    • 4 Reset the console buttons if the incline is not working properly on the machine. Insert the console key and press one of the "Incline" buttons. While the incline is in the process of changing, remove the console key. Wait two or three seconds and re-insert the console key.
    • 5 Remove the console key and unplug the Pro-Form device if none of the above steps are resolving the problem with the console keys. Unscrew the three screws that hold the motor hood on the front of the device and pivot the hood off the machine. Find the magnet and small reed switch on the left side of the pulley. Turn the pulley until the magnet is aligned with the reed switch and the gap between the two is approximately 1/8 inch. Reattach the hood, screw into place and turn the treadmill back on
If you need further assistance, please reach me.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Oct 16, 2011 | Proform XP Weight Loss 620 Treadmill
My nordictrack is stuck on a program &wont let u do anything else..cant change the speed or incline &the fans wont turn on..its like the consol is frozen or stuck on a program..how can i reset it...
How to Troubleshoot a Nordic Track C2500 X15616db0-ef56-4f0a-afbd-b1ae3379f47f.small.jpg Jolie Johnson
Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
By Jolie Johnson, eHow Contributor
updated April 15, 2011
Related Searches:
The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
Instructions
  1. Power Turns Off When You're Using the Treadmill
    • 1 Check the reset switch on the bottom of the treadmill near the power cord. If it has tripped, the top of the switch will protrude. Wait 5 minutes then press the switch.
    • 2 Check that the power cord is plugged in completely. If it is plugged in, unplug it, wait 5 minutes then plug it back in.
    • 3 Remove the magnetic key from the console then reinsert it.
    The Console Won't Turn Off
    • 1 Insert the magnetic key into the console. Your C2500 is stuck in demo mode if the console won't turn off after you remove the magnetic key from the console.
    • 2 Hold the "Stop" button down for a few seconds.
    • 3 Press the "Speed" down (-) button. Remove the magnetic key.
    The Incline Does Not Change Correctly
    • 1 Press and hold the "Stop" and the "Speed" up (+) button. While holding the buttons, insert the key into the console, then release the buttons.
    • 2 Press either the "Incline" up or down arrow button. Wait while the incline raises and lowers. This recalibrates the incline system.
    • 3 Remove the key from the console.
    Walking Belt Slows
    • 1 Unplug your C2500 and remove the key from the console.
    • 2 Turn both rear adjustment bolts, located on the back of the walking deck, to the left, a 1/4 turn.
    • 3 Lift the edge of the walking belt in the middle of the deck. You should be able to lift it 2 to 3 inches off the walking platform. If the belt is still too tight, loosen the bolts another 1/4 turn each.
    • 4 Plug the treadmill in and reinsert the console key. Walk on the belt at a slow speed to see if it still slows. Repeat Step 2 if necessary.
Sep 27, 2011 | Nordic Track NordicTrack Treadmill, A2550
I cannot get it to incline. It will say it goes from .5 to 10 and not incline at all
First perform an incline calibration. The procedure is outlined in your users manual.
It is a simple procedure. Insert the safety key and start the machine in motion. Press the incline up button. While the numbers are increasing remove the safety key.
Now reinstall the safety key, the machine should incline to maximum then lower back down to minimum.
Now you can operate the treadmill, the incline should work.
Jan 04, 2011 | Proform CrossTrainer Treadmill
Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jul 15, 2010 | Proform Exercise & Fitness
My proform 360p treadmill is stuck on full incline - can it be fixed and if so how???
try thisSometimes incline motors will get frozen in position and need broke free. Try this:
take the motor cover off and take the screw out of the bottom of the incline motor that is attached to the screw assembly. Once you remove the screw you should be able to break the incline motor free. run the incline up and down with the screw still off( laying the treadmill on its side may make this easier). Once it goes up and down (hold the screw so it goes in and out) reattach it then run the calibration described below. If it was just stuck it should work fine.
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
If these instructions do not work to fix the incline motor
check your main harness running down the right leg for breaks in the wires or a loose connection if nothings found you can switch the red and black wires on the incline motor terminal block and see if it goes down. If it does you know you are only getting voltage to one side of the motor. There is a schematic under the motor hood that tells you what the voltage should be when you press the up or down keys. Use a multi-meter to see if you are getting the correct voltage coming from the console to the motor control board and then from the board to the motor. If no voltage from console-replace console if you have voltage from console but not from board - replace board and finally if you have voltage from console and from board replace motor. You will need to test the voltage both when pressing the up key and the down key.
Jul 14, 2010 | Proform Exercise & Fitness
Nordic Track NordicTrack T6.3 Treadmill Logo
37 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
