Question about Craftsman 24 Hp 48" Deck Yard Tractor
My craftsman yard tractor all of a sudden will not move, 42 " cut , 15.5.hp kohler motor Hydrostatic drive ,!
Moved from my back yard up to house to repair rear tire& after I fixed the tire the machine would not move forward or reverse, just makes a whinihg noise & the belts are intact, but after removing the rear cover I saw a broken spring on thr e left side wmhich can be moved back and forth by hand but when released it goes to the center posistion. Thanks
  • Paul Gray
    Paul Gray Apr 01, 2014
    I did remove the left rear tire.
  • Elizabeth Gostevskyh
    Elizabeth Gostevskyh Apr 01, 2014
    how mechanically inclined are you? can i trust you that you removed the tire like a normal guy or did you rig the tracker up with blocks and a towe rope or something? I'm thinking you may have broken the the spring that puts your tractor in lay over. walk me through your tire repair.
    Guru:
  • 145 Answers
Bypass rod pulled out to allow pushing the tractor, the noise is the hydrostat bypassing fluid (normal) if my crystal works
Posted on Apr 14, 2014
  • 138 Answers
SOURCE: engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Posted on Aug 24, 2009
mickey813
  • 472 Answers
SOURCE: my craftsman lawn tractor has a 42 in. deck, w/21
YOUR TRANS IS BAD
Posted on Oct 02, 2009
SOURCE: NO FORWARD NO REVERSE
I had the same problem so I looked under the mower and the belt that goes from the engine to the back of the mower was off so I pushed the clutch as far forward as I could and the belt went on it and it worked
Posted on Aug 09, 2009
mickey813
  • 472 Answers
SOURCE: 24 hp. garden tractor goes in reverse but not forward
SOUNDS LIKE ITS TIME FOR A NEW TRNS AXEL
Posted on Oct 30, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman 24 hp 42 in. Deck Yard Tractor problem.
the gears inside rearend are bad either sheared the key inside or the spider gears have teeth missing
Posted on Nov 10, 2009
Something snapped on my tractor and now the back drive axle swivels independantly,no longer following the front,can you tell me what it might be
there is a drag link that steers the rear in relation to the front. It has probably broken at a thread lock nut and fallen down
Jun 12, 2013 | Craftsman 46" 22hp Kohler Powered Turn...
A bad shutter when hydrostaic is engaged
take it back from where you bought it and get another.
Jul 20, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My riding mower workes fine fore about 45 mintes then it slowes down wants to move real slow and wont pull my yard sweper anymore. The blades engage just fine, the motor starts/runs fine It just moves slow...
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine cuts out when engaging clutch or engaging blades..
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Hydrostatic Transmission Failure
There is a transmission bypass lever on the back of the mower, if the bypass is moved out of the drive position, it will not drive in either direction, and will be really easy to push.
May 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 24 Hp 48" Deck Yard Tractor Logo
172 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
