Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Frigidaire glrs264za ice in freezer
There is a huge chunk of ice in the bottom of my freezer. Looks like it's coming from the back of my freezer wall. I'm not quite sure what's back there and what I'm looking for, or if mine has the drain tube I keep seeing mentioned. Any help is greatly appreciated!!
    Problem Solver:
  • 17 Answers
The ice-maker supply line enters the back of the freezer near the top. There is a rubber piece that fills the ice tray, attached from the outside. If that is cracked you will have a leak. There is also a water line that runs through the refrigerator to the reservoir that supplies chilled water at the door. All of these lines should be checked for leaks that can drip into the freezer compartment.
Posted on Apr 01, 2014
the dr
  • 447 Answers
SOURCE: Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Posted on Nov 25, 2007
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
docjohn174
  • 943 Answers
SOURCE: Frigidaire FRT18IL6D
Hi thanks for your question. to unclog. pull fridge away from the wall. remove back cover , clean all coils. let fridge thaw for at least 24 hrs. get small plastic hose to push up the drain tube from the back. blow up yhr drain tube to clear the tube. thanks the appliance doc. please rte my answer, thanks.
Posted on Oct 12, 2008
larryyb
  • 291 Answers
SOURCE: Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Posted on Nov 25, 2008
  • 2976 Answers
SOURCE: accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Posted on Feb 02, 2009
Why would I have frost on the back of the refrigerator?
Ice or Frost on Back Wall of Refrigerator ' FAQ ' Sub-Zero ...
www.subzero-wolf.com/.../ice-or-frost-on-back-wall-of-refrige...
Sub?ZeroWhy is ice forming on the back wall of the refrigerator? ... The settings should be 38 in the refrigerator, 00 in the freezer, or 4-6 if the unit has a dial control.
Jan 01, 2016 | Frigidaire Refrigerators
The defrost cycle seems to stay on too long-ice already made will start melting & then refreeze into 1 big chunk. Eventually the "melt" will build up in the bottom of the freezer & will eventually...
if think your defrost cycle is ok . there is a defrost terminator that controls the heater at 50 deg in the back of freezer , the problem is the water delivery tube is iceing oven and causing water to run down the back of freezer wall . change the tube to newer style. it will be open on the top side . they work better. and the water valve may be leaking through. and may have to be changed .. ,,
Jul 29, 2010 | Refrigerators
Clicking sound coming from the vent area on the top back left wall on frig side of a Frigidaire GLRS264ZA. The clicking sound comes and goes. Frig and freezer still seem to be working fine. Any ideas on...
the clicking is probably normal . in that area is the a d c some thremostates / . can't be fan as it in freezer ,, don't fix what isn't broken . relays have just a light click / they are not very loud . with the door closed you should not be able to hear them. mm
Dec 09, 2009 | Frigidaire GLRS264ZA Side by Side...
Ice under the bottom draw in freezer. Melts some
Close, it is in the freezer.
It is your defrost drain. that ice was actually ice originally, just from your evaporator. the defrost heater comes on when the evap. gets frosty white, it melts, and then is supposed to go down your drain. if it is clogged, it will build up, and just freeze because it is around zero in there. my advice, take off the back wall of the freezer, look for the drain under the aluminum coils that is toward the back wall. get your moms hair dryer and go at it
Oct 07, 2009 | Frigidaire FRS26R4A Side by Side...
My icemaker is making huge chunks of ice in bin
You will need to replace the termination thermostat. What sounds like is happening is. Every 8 to 10 hr. your freezer goes into defrost for a set period of time. There is a termination thermostat that senses the temp at you evaporator coil in you freezer. When you heaters come on they defrost the ice from your coil. once the termination thermostat senses the temp has gotten to a preset degree, it cuts the power to the heaters. This keeps the heaters from staying on the whole period and making your freezer warm. After the pre set time period the timer turns the compressor back on. What it sounds like is happening is the termination thermostat is not opening, cutting the heaters off. By not doing so, it's letting your freezer get above freezing, melting your ice some. When the timer advances into cooling again it freezes your ice together. I would say it's your water valve leaking but that would make large pieces of ice that the ice maker has trouble dumping and also sometimes a large chunk that does not look like cubs. That would also eventually freeze the inlet tube closed..
Please rate solution
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have water leaking out the back of the freezer side of my side
Pull the fridge away from the wall and check where the water line enters the fridge for the ice maker. If there is a fitting there, make sure that it is tight or the clamp is secure. If it looks cracked or split in any way, remove it and replace it with new hose.
Hope this helps,
Jeff
Jul 08, 2009 | Frigidaire GLRS264ZA Side by Side...
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Nov 25, 2008 | Frigidaire Refrigerators
Ice in the bottom of frigidaire side by side frost proof freezer
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
76 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
